Mr.Avantgarde skrev:Hvor har du det fra, at et bestemt kabel skulle fungere særligt godt med højttalere med en følsomhed over 100db/W?
Den er jeg ligegodt aldrig stødt ind i før
Cardas har en SE-kabelserie, som I kan læse mere om
her (scroll ned i bunden) samt se specs under de enkelte SE-kabler. Her er et snip fra
dette indlæg, hvor en Cardas-medarbejder citeret fra en mail uddyber:
Our line of SE speaker cables was designed to be used with low power amplifiers and high efficiency speakers. The name "SE" is a bit of a marketing decision since as you pointed out the speaker cables can be used with any type of amplifier.
In all speaker cable applications the goal is to have just enough copper to transfer the required current without limitation. If you have too much copper you will have extra inductance and end up storing energy inside the cable for no reason. This extra copper can make the sound worse.
So as you can see all speaker cables must have a good balance and this balance should also have a synergy with your amp and speakers.
If your speakers are 99 db then they require much less power to drive than a speaker rated at 87 db and will also draw much less current; so the speaker cable for the 99 db speaker can be much smaller overall gauge assuming you are running them the same length.
I hope this helps you understand our vision for the SE speaker cables.
Cheers,
Brian Von Bork
Technical Support
Cardas Audio
480 11th Street, SE
Bandon, OR 97411
Mine 107 dB/W/m 18 Ohm højttalere kræver nærmest ingen strøm ved mit normale lytteniveau på 75-80 dB (læg selv passende peakværdi oveni), og min single-ended First Watt J2 (25W ved 8 Ohm) har absolut ingen problemer med at drive dem. Men giver det mening, hvad Cardas påstår? Er fx SE-15 det rette kabel at gå efter, når nu SE-9 på papiret har lavere induktans (og højere kapacitans, men det er mindre vigtigt i denne sammenhæng)?
Burde jeg i stedet kigge efter nogle Kondo-kabler i kobber (KSL SPc, har ikke råd til sølvkablerne), og i givet fald hvorfor?
Totaldac REFERENCE-D3, First Watt SIT-2, Avantgarde Duo Omega G2, SVS PB13-Ultra, OPPO BDP-93, Panasonic 65" VT30Y, Blue Jeans Cable
