Dac tilspilning
Dac tilspilning
Indlægaf tonykart007 » fre mar 30, 2012 16:29
Kræver det af den bliver fødte med musik eller skal den bare være tændt ?
Tonykart007
tonykart007
Tilmeldt: lør jun 13, 2009 12:31
Re: Dac tilspilning
Indlægaf kennethjensen » fre mar 30, 2012 17:23
Musik igennem.
kennethjensen
Re: Dac tilspilning
Indlægaf ZulluZ » fre mar 30, 2012 19:34
Ja kredsløbene skal stimuleres med musik, for at blive indspillet   :lol:
Fandt lige dette da jeg læste en review af Amr dp-777
Burn-In Tips (How to make fast and effective burn-in)
1. Input: One needs to have a signal input during burn-in. Just turning on the equipment without putting a signal through it is not as good. The equipment needs to burn in with both AC and DC signals. Putting a music signal through will ensure there are AC voltages going through the circuit, not just DC voltages.
2. Output:One needs to put a load to the output. So for burning-in DACs, one needs to connect it to the Pre-Amp; for burning-in Pre-Amp, one needs to connect it to the Power-Amp; for burning-in Power Amps, one needs to connect it to the speakers and so on.
3. No need to listen to it (but need to have music signal). How? For example, if you are burning-in a DAC, have it connected to the Pre-Amp is sufficient, no need to turn the Power-Amp ON, or you can listen to something else (e.g. LP) while burning in the DAC.
4. Tube gears usually need longer burn-in time than solid stage gears. Audiophile capacitors will need longer burn-in time than surface mounted (SMD) capacitors; even cables needs burn-in. Most stuff in High-End needs burn-in, except speaker spikes I guess :-)
5. Burning-in speakers are the most painful as they really need to have sufficient sound level output. Bookshelf speakers are easier to handle. Let the speakers face each other with 1cm gap in between, then reverse ONE speaker’s polarity (so their respective sound output will cancel each other out by a large extend), finally put a blanket over the speakers and blast away.
That’s all for now, happy burning-in!
ZulluZ
Tilmeldt: tirs mar 20, 2012 16:23
Re: Dac tilspilning
Indlægaf allanowich » lør mar 31, 2012 12:23
Egentligt behøver den blot at stå tændt. Det er jo ikke et bevægeligt medie. Når du lige får den fra ny vil det være en fin ide,at lade den stå tændt i 24timer inden du bedømmer den første gang. Derefter kan du blot tænde den nogle timer før du skal lytte. Sidder du af og til og lytter mere kritisk til musikken, kan du tænde dit udstyr dagen før. Det kan høres.
Højttalere og pick upper skal til gengæld bruges aktivt for at tilspille ophængene.  :)
allanowich
Re: Dac tilspilning
Indlægaf tonykart007 » lør mar 31, 2012 13:43
Jeg havde den tændt i 5 timer igår før jeg lyttede på den. Jeg synes den åbner sig mere og mere. Den er i hvert falde klasse bedre en min gamle an rør som faktisk manglede en del på hele spektret. Folk har flere gange udtalt at en stock an dac 1 er død i bunden og det kan jeg hører nu. Den ny dac har MEGET nærvær, krop, fylde, detalje, soundstage og ikke mindst en del bedre bund. Og den er nok ikke tilspillet helt endnu.
Tonykart007
tonykart007
Re: Dac tilspilning
Indlægaf allanowich » søn apr 08, 2012 00:15
Aaarh, du kan nok høre lidt forskel lidt endnu som tiden går.  :)
allanowich
Re: Dac tilspilning
Indlægaf tonykart007 » man apr 09, 2012 10:22
Den har stået og spillet i 2 x 15 timer nu indenfor de sidste dage, så den er nok lidt mere tilspillet.
Tonykart007
tonykart007
Re: Dac tilspilning
Indlægaf micma18 » man apr 09, 2012 17:41
Hvis du vil tilspille audio kredsløbene, så skal der altså være signal på den. Men som jeg forstår anbefalingen i svar #2, så er det IKKE nok, bare at DACen er tilsluttet din forforstærker, men lytter til et andet apparat! Belastningen af DACens udgangstrin, opstår først, når indgangs vælgeren står på DAC indgangen.
Der findes sikkert også forstærkere, hvor indgangs kredsløbet helt frakobles, når det er slukket! Så det dur heller ikke i alle tilfælde at spille med en slukket pre.
(evt. køb to skod RCA stik, og slut det med en 20Kohm modstand, så er belastningen tilstede.....)
Men ændringen ved tilspilning kan sagtens høres som mest udpræget i den første time eller endnu mindre. Det er dog nok ikke tilfældet, hvis apparatet har været burn-in testet fra fabrikken, hvilket man da må håbe, det meste grej er ;-)
Men det bliver nok mindre og mindre ændring man oplever, jo flere timer det får lov at spille. Om man kan huske hvordan det spillede for 100 timer siden er nok også en anden sag. :-)
micma18
Tilmeldt: tors dec 10, 2009 10:22
Re: Dac tilspilning
Indlægaf larsne » tors apr 12, 2012 09:14
larsne
Tilmeldt: lør dec 09, 2006 22:45
Re: Dac tilspilning
Indlægaf tonykart007 » tors apr 12, 2012 09:41
Har aldrig taget ham og hans side seriøst. Han er tilsyneladende en person som elsker at hører sig selv snakke eller se sig selv skriver. Det er sjovt at han hele tiden skriver vi når man som på hifi4gige ved der kun er en tosse. Micma hjælper jo bare. Om han så bliver bagtalt på en ligegyldig hobby hjemmeside som kun få nok ser, er det vel ligegyldigt.
Tonykart007
tonykart007
Re: Dac tilspilning
Indlægaf Andre´ Jensen » tors apr 12, 2012 10:15
Har i overvejet, selvom det sikkert er usandsyndligt, at manden har ret i tilspilning er vrøvl. Argumenterne poul nævner, lyder ikke helt tosset.
Jeg vil gå så langt, at argmenterne for, er ligeså gode som argumenter for
astrologi.
Re: Dac tilspilning
Indlægaf tonykart007 » tors apr 12, 2012 10:45
Efter min mening er tilspilning ganske reelt nok. Har flere gange oplevet at tilspilning var hørbar. Men det er også mere måden Poul bagtaler andre via hans blog, jeg ikke bryder mig om.
Tonykart007
tonykart007
Re: Dac tilspilning
Indlægaf sd2100 » tors apr 12, 2012 11:08
I den virkelige verden (den professionelle del), er man åbenbart ikke helt uenig med Poul:
http://harbeth.co.uk/uk/index.php?secti ... age=faq#16
men, på den anden side, hvad ved de om noget som helst :?
sd2100
Tilmeldt: man jan 30, 2006 11:21
Re: Dac tilspilning
Indlægaf Jonas_h » tors apr 12, 2012 11:16
tonykart007 skrev:Efter min mening er tilspilning ganske reelt nok. Har flere gange oplevet at tilspilning var hørbar. Men det er også mere måden Poul bagtaler andre via hans blog, jeg ikke bryder mig om.
Har du rent faktisk verificeret dette i en blindtest hvor du har to identiske komponenter hvor ét er tilspillet og ét ikke er?
Jonas_h
Re: Dac tilspilning
Indlægaf Andre´ Jensen » tors apr 12, 2012 11:19
Nu er der ganske mange der mener astrologi virker  :wink: .
