Her er lidt sakset fra denne side ang. en persons tanker om diverse MM'ere:
http://daveyw.edsstuff.org/vinyl/cartri ... artridges/(der kan endda lytttes på siden - download)
ADC
36 QLM III
MM
Approx 10 Hrs
Recording Level 8.2
Tracking 1.2g
Bias 1.2
Dave's Thoughts:Overall a generally neutral balance. Vocals and strings are a little recessed. Higher frequencies not as forward as in the Goldrings or AT 440.
Note: Although the stylus is new it looks like it is a re-manufactured item.
Audio Technica
AT 95e
MM
Approx 100 Hrs
Recording Level 7.3
Tracking 2.0g
Bias 1.8
Dave's Thoughts:Well extended bass but not as tight as other MM's. Upper midrange and treble slightly rolled off leading to a lack of definition to some instruments and vocals. No notable sibilance but upper frequencies lack some bite and attack.
Audio Technica
AT 150MLX
MM
Approx 10 Hrs
Recording Level 6.8
Tracking 1.25g
Bias 1.1
Dave's Thoughts: Possibly seen as a MM version of the AT 0C9 MLII. Some of the OC9 treble lift is retained, but it is less pronounced. Also the lower mid range is filled out a little, losing some of the slightly lean character of the OC9. However, I did find that the 150MLX was not quite as open and spacious as the OC9. Overall a highly refined and articulate cartridge, delivering a more neutral presentation than the AT440MLa and AT0C9MLII.
Audio Technica
AT 440ML OCC
MM
Approx 50 Hrs
Recording Level 7.0
Tracking 1.25g
Bias 1.3
Dave's Thoughts:Taut bass but leaner than the Goldring 1042, sweet midrange and vocal coverage with an extended treble. This is a refined and exciting listen but generally bright, needs to be carefully matched.
Audio Technica
AT 440MLa
MM
0 Hrs
Recording Level 7.0
Tracking 1.4g
Bias 1.3
Dave's Thoughts: Recorded "Out of the box": Marginally leaner bass than the G1042 but slightly deeper than the AT440ML OCC. Rich mid-range & vocals with a more subdued treble lift as witnessed on the AT440 ML OCC, clean and precise percussion. Overall still a bright yet refined, taut and punchy cart.
Follow Up: Cartridge re-appraised at approx 40 Hours - I was unable to detect any noticable change in character.
Audio Technica
AT 5625AL
MM
Approx 30 Hrs
Recording Level 7.0
Tracking 2.0g
Bias 1.8
Dave's Thoughts:Quite a deep bass but lower frequencies could be tighter. Midrange (vocals, guitars and strings etc.) a little veiled and lacking the clarity of the better MM's. Upper frequencies, including cymbal splashes, lack some life. Soundstage also notably narrower than the other better MM's.
Audio Technica
AT 5625AL Expert Stylus Para-Trace
MM
Approx 10 Hrs
Recording Level 7.0
Tracking 2.0g
Bias 1.8
Dave's Thoughts:Very similar in character to the standard AT-5625AL, some very subtle improvements in low frequency control and upper frequency refinement. Would recommend purchase of a better quality cart instead of re-tipping a low cost item.
Goldring
Elektra
MM
Approx 50 Hrs
Recording Level 5.8
Tracking 1.8g
Bias 1.7
Dave's Thoughts:Good wide soundstage. A strong, tight bass response - Double bass well controlled and not at all flabby. Midrange and upper frequencies well defined, broad and open. Instruments and vocals are cleanly defined. Percussion is crisp and sharp without being over exuberant. Is bettered in overall refinement by the top flight MM's and MC's, but an excellent performance from a budget item.
Goldring
1012GX
MM
Approx 200 Hrs
Recording Level 7.0
Tracking 1.5g
Bias 1.6
Dave's Thoughts:A punchy strong bass, dynamic overall sound, some slight harshness in the upper frequencies when compared to the 1042..
Goldring
1042
MM
Approx 200 Hrs
Recording Level 7.0
Tracking 1.5g
Bias 1.6
Dave's Thoughts:Although the 1012GX does a pretty good job, the 1042 does everything that bit better. Bass is tighter (and still strong), vocals cleaner and slightly more forward. A more refined treble, especially in the higher frequencies. A very dynamic and engaging cartridge.
Linn
K9
MM
Approx 200 Hrs
Recording Level 7.5
Tracking 1.75g
Bias 1.6
Dave's Thoughts:Good overall performance although it was difficult to eradicate all sibilance during set up. Other MM's (especially the Ortofon 2M Black and AT 440MLa) offer enhanced midband separation plus extra control to the higher frequencies.
LP Gear
Deft 2
MM
Approx 8 Hrs
Recording Level 5.8
Tracking 2.0g
Bias 1.8
Dave's Thoughts: A good quality budget offering. Bass response lacks that ultimate control when compared to the best MM's. A warm overall presentation and a good option for those wanting to avoid or tame a bright front end, look elsewhere if you want some bite and attack.
Ortofon
2M Black
MM
Approx 20 Hrs
Recording Level 5.0
Tracking 1.5g
Bias 1.4
Dave's Thoughts: Tight, controlled and punchy bass, well balanced tonally, no notable accentuation of any specific frequency range. A very strong performing MM with relatively high output (despite the 5.0mV spec.). Marginally bettered by the AT OC9 ML II and DV 17D3 Karat for midrange transparency and upper frequency extention and crispness.
Ortofon
510 Mk II
MM
Approx 200 Hrs
Recording Level 6.4
Tracking 1.5g
Bias 1.4
Dave's Thoughts: A good capable performance from an entry level MM. Vocals a little recessed and upper frequencies not quite as crisp as the better MM's.
Ortofon
530
MM
Approx 200 Hrs
Recording Level 6.9
Tracking 1.3g
Bias 1.2
Dave's Thoughts: Well controlled and punchy bass with a totally neutral and refined presentation throughout the frequency range, similar in character to the VMS30 II. Articulate and clear without the slightly bright edge of the AT 440MLa.
Shure
M75 ED II
Shure ED-T2
MM
Approx 200 Hrs
Recording Level 6.2
Tracking 1.2g
Bias 1.1
Dave's Thoughts: Taut bass with good depth, well defined midrange with all vocals and instruments being well defined. Although cleanly presented, upper frequencies are marginally recessed when compared to the V range of Shure Carts giving it a slightly warmer overall presentation..
Shure
M75 ED II
Pfanstiehl
4760-DE
MM
2 Hrs
Recording Level 4.4
Tracking 2.0g
Bias 1.8
Dave's Thoughts:Again, taut bass with good depth. Vocals and instruments being reasonably well defined. Upper frequencies are presented a little further forward in the mix when compared to the ED-T2 stylus, however it does lack some of the refinement.
Shure
M95-ED
Jico Stylus
MM
Approx 65 Hrs
Recording Level 6.9
Tracking 1.0g
Bias 1.0
Dave's Thoughts: A significantly different character to the V15 III. This is altogether brighter with an extended treble that borders on harsh at times. Midrange, especially vocals are also a little ill-defined when compared to the better MM's.
Please note that there is a notable hum on the sound clips. This was prevalent when first installed and gradually regressed on useage.
Shure/Realistic
R47XT
MM
Approx 50 Hrs
Recording Level 6.0
Tracking 1.2g
Bias 1.1
Dave's Thoughts:Overall a very mellow presentation. Upper midrange and treble recessed when compared to most MM's. Compared to the Shure V15III or the M75 ED this is a little lifeless.
Shure
V15 II
Improved
MM
Approx 10 Hrs
Recording Level 7.0
Tracking 1.3g
Bias 1.1
Dave's Thoughts: A similar character to the M75 ED II. Again an overall warm presentation but with improved openess in instrumentation and vocals. The top end is slightly more forward giving it a slightly brighter tinge.
Shure
V15 III
MM
Approx 100 Hrs
Recording Level 7.0
Tracking 1.0g
Bias 1.0
Dave's Thoughts: A very musical cartridge that drags you into the whole as opposed to accenting any specific dynamic, yet all instruments remain well defined. Tracks difficult passages very well. A well balanced, neutral and musical cart.
Shure
V15 VST V
MM
Approx 300 Hrs
Recording Level 7.0
Tracking 1.5g
Bias 1.4
Dave's Thoughts: Builds on the strengths of the V15 III, delivering a strong controlled bass, well defined vocals and midrange with crisp refined highs. A highly engaging cartridge - bold, controlled with an articulate presentation.
Stanton
500
MM
Approx 300 Hrs
Recording Level 6.0
Tracking 2.0g
Bias 1.8
Dave's Thoughts: Deep and reasonably tight bass, vocals and midrange instruments lack definition on complex tracks when compared to the better MM's. Emphasised treble with some harshness in percussion and sibilance on vocals. These failings are less evident when playing straight forward Rock and Pop.
Stanton
500
D71EE
MM
2 Hrs
Recording Level 7.3
Tracking 1.3g
Bias 1.2
Dave's Thoughts: Bass remains strong but a little tauter. Midrange separation, especially vocals and strings, is notably improved. The higher frequencies remain accentuated but are much better controlled, some slight sibilance remains, however the high hat splashes are significantly crisper. Not a giant killing cartridge, but if you have a 500 and want a cheap (20USD) upgrade then this is certainly a good option especially if Rock and up tempo Pop music is your thing.
Stanton
500 II
D71EE
MM
2 Hrs
Recording Level 7.5
Tracking 1.3g
Bias 1.2
Dave's Thoughts:Much of the overall character of the 500/D71EE was preserved, however some of the accentuated treble returned along with mild harshness to the percussion and notable sibilance. This failing did marginally regress with increase VTF. Once again though throw some fairly basic Rock and Pop at it and it will have your feet tapping. Tight, punchy and great fun, if not overly subtle.
Stanton
881S
D81S-II
Without Brush
MM
50 Hrs
Recording Level 6.4
Tracking 1.0g
Bias 0.9
Daves Thoughts: A deep bass response with a small element of added punch over the 681. Again a slightly warm presentation to instruments and vocals but with further added clarity and separation over the 681. Upper frequencies are cleanly presented without any sibilance and are a little furhter forward in the mix over the MI 681. Overall an intriguing combination - A strong, refined and slightly warm presentation, without at all being dull.
Stanton
881S
D81S-II
With Brush
MM
50 Hrs
Recording Level 6.4
Tracking 2.0g
Bias 1.8
Daves Thoughts: I struggled to pick up any notable differences in presentation with and without the brush.
However, on some pressings slight background noise was occasionally picked up by the trailing bristles when in contact with the lead in groove. This is evident here on Clip 1.
Stanton
CS-100
MM
150 Hrs
Recording Level 6.8
Tracking 1.0g
Bias 0.9
Daves Thoughts: Upper frequencies are notably more forward and it does not possess some of the warmth and extended lower mid/upper bass of the 881s/681EEE. Quite lean in the bass/mid presentation, you get something more akin to an AT MM approach. However, it is very well controlled, no wooliness in the bass - in fact very tight. Although a little bright, there's control with no sibilance or harshness.
