af tommy h » lør mar 16, 2013 18:26
ABOUT THE BALANCED INPUT JACKS
q The PM-11S1 uses XLR connectors for the BALANCED INPUT jacks. XLR connectors are widely used with profes- sional equipment because of the following features.
• Incoming music signals are balanced, therefore they are
little affected by external noise.
• The detachable locking mechanism minimizes connec-
tor play and enhances connection reliability.
w There are two ways to connect the XLR connectors. 1.In the USA
1 GND
2 1GND
HOT COLD
e The PM-11S1 adopts the USA circuitry. If the PM-11S1 is connected via a balanced cable to a preamplifier or control amplifier of European circuitry, signal phases will be re- versed. To correctly align signal phases, switch the w and e pins of one of the XLR connectors.
COLD 2 HOT
2.In Europe
Har lige sakset lidt fra manualen, men det fortæller vel ikke om det er ægte?
