Indlægaf gurdet » tors apr 11, 2013 20:44
ZIG skrev:Meget meget morsomt, dreamz! 8)
Og jeg er glad for, at du orker at fortsætte vores diskussion, for jeg synes, at Nerds er blevet et meget kedeligt sted, hvor der egentlig ikke sker noget.
Det lykkes dig i dit indlæg at illustrere, at min position er absurd. Det gør du ved hjælp af retoriske kneb, der er ganske virksomme og slutresultatet står ved magt!
Men rent logisk har du ikke bevist noget som helst. Så jeg vil vende tilbage til logikken.
Signalering er en meget kompliceret affære.
We seem to give more attention to the signals we send, vs. interpreting the signals of others. For example, we think more about what we will wear than about the judgements we form based on what other people wear.....
For our distant forager ancestors, their most important public speaking probably happened in situations where they were being accused, and needed to defend themselves. Since the generic accusation behind any specific accusation was that one wasn’t doing enough overall for the band, and maybe should be exiled or killed, our ancestors should have been eager to collect examples of the help they have given, especially unheralded help. So we may have inherited a habit of doing helpful things, and not calling attention to them, but remembering them so we could mention them later if called on to defend ourselves.
More generally, our ancestors probably acquired the habit of consciously thinking about actions that others were likely to challenge or criticize. They’d continually come up with explanations of what they did and why, and be ready to tell those stories, even if they didn’t actually have to explain or justify most of them. And because they were rarely asked to justify or explain the judgements they made about others, they didn’t get into as much of a habit of explaining those.
This theory predicts that we in fact give just as much mental attention to buying as to selling, and just as much to interpreting signals as to sending signals, because these are in fact on average equally as important to us. But we give a lot more conscious attention to the side that needs to be explained, because that is what consciousness is about – consciousness helps much less to make decisions than to explain and justify them.
(Robin Hanson @overcoming bias)
Så, altså, ifølge Robin og Zig har du f.eks. dreamz ikke priviligeret adgang til dine motivationer. Du kan sige en helt masse om dem - men talens egentlige formål er den offentlige modtagelse (med andre ord PR) fremfor en dyberegående selvransagelse.
Som udenforstående har jeg faktisk bedre mulighed for at gætte mig frem til den egentlige motivation, end du selv har - (hvis nu jeg er sådan en særling der går op i andres signaller mere end mine egne).
Gad vide, om den forklaring havde tilfredsstillet vores forfædre, eller om Zig og Robin var endt på hver sin stage....
God ide med noget Patti Smith, Macwerk! Pissin in a river har jeg godt nok ikke hørt i umindelige tider.
Mens jeg endnu gik alene og konfliktramt hjemme tidligere på dagen, havde jeg den her på:
Michael Formanek: The Rub and Spare Change (2010)
(betyder hvad, Zig?)
En rigtig ECM'er - suveræne musikere, der maler landskaber
Indlægaf dreamz » tors apr 11, 2013 23:27
Så kan vi læse tanker?
Ja, det kan vi, og det gør vi hele tiden.
Og nu skal jeg lytte til musik og få lidt trøst....
Mageløst, ZIG, ganske enkelt mageløst. Hvis du mener, jeg benytter mig af retoriske kneb, må jeg sige, at jeg i dig har fundet min overmand.
Først antyder du, at min tilgang til musik udelukkende har til formål at udsende signal om, at jeg har en moderne identitet. Da jeg så efter fattig evne forsøger at imødegå denne uhyrlige påstand, triller du så den ægte retoriske perle på bordet:  Et ekstrakt fra en eller anden økonomiprofessor, der ifølge din konklusion betyder, at hvis man finder det nødvendigt at argumentere for sit synspunkt, er det udelukkende af hensyn til ”den offentlige modtagelse (med andre ord PR) fremfor en dyberegående selvransagelse.”
Tak for kaffe! Knebet er jo klasser bedre end det velkendte spørgsmål ’Hvornår er du holdt op med at slå din kone’?
Havde jeg ikke forsvaret mig, ville du få ret, og nu hvor jeg så har forsvaret mig, får du også ret. Og for at fortsætte i den lommefilosofiske rille; Hvad enten jeg forsvarer mig eller ikke forsvarer mig, du vil få ret i begge tilfælde (frit efter Kierkegaard).
I rest my case og lukker mig ind i en postmodernistisk tilstand af selvransagelse. Jeg må indse, at min jagt efter den gode musik, den ultimative musikoplevelse har været et falsum. Tak ZIG. Tak Robin. Tak fordi I har givet mig mulighed for at se lyset. Mon Larry Carlton står og spiller for enden af tunnelen?
Indlægaf Kristian » fre apr 12, 2013 08:28
gurdet skrev:Der er konstante henvisninger til The Fall alle steder, hvor man læser om Pere Ubu. Kristian har også gang i dem. Jeg bukker under for min nysgerrighed.
Har købt denne, som "de kloge" siger, er et godt startsted:
The Fall: Hex Enducation Hour (1982)
Den tager lidt tid at fordøje, men jeg er på... så jeg har lånt en bog:
Dave Simpson: The Fallen (2008)
Forfatteren har sat sig for at finde frem til de efterhånden 50 personer, der har været - men ikke længere er - medlemmer af bandet. Jeg er endnu ikke så langt, men underholdende er det i hvert fald at læse om Mark E Smiths måde at håndtere sit band.
Spørgsmålet er nu, Kristian: What next?
@Gurdet, er du blivet til en Fall'ist nu?
Det var et kult omkring dem, "the fall'ist"
Der kommer en nye en fra M.E.Smith
http://pitchfork.com/news/50281-the-fall-announce-new-album/
tror det bliver dub/ska/reggae og country funk i weekenden
Indlægaf ZIG » fre apr 12, 2013 09:10
Det var så det.
Ethvert postmoderne menneske har brug for tre ting:
i) En handleplan
ii) En behandlingsplan
iii) Evidens
iv) En god opskrift på Chile con Carne
Igen vil jeg bruge dreamz som et eksempel.
Handleplan
Lyt til den her knægt:
Den kan ovenikøbet downloades gratis, hvis du lige kikker forbi Stereophile først. Effekten vil være som en lun brise, hvor du blotter dit bryst og råber ud over den ganske verden "Fisse".
Behandlingsplan
Køb (uden først at lytte til den) en af gurdets plader (af en kunstner du ikke har hørt før). Tag den med hjem og spil den mindst tre gange i træk. Det kunne f.eks. være Michael Formanek: The Rub and Spare Change. Hvilket jo vil være meget relevant, hvis du også en dag bliver lockout'et.
Evidens
Læs denne artikel:
http://www.scottaaronson.com/papers/agree-econ.pdf
Herefter vil du opdage, at vi er enige og du vil invitere på en omgang Chile con Carne eventuelt lavet efter denne opskrift
2 Peberfrugter,
3 mellemstærke chilier og
3 store løg blancheres.
450 g oksefars brunes og det hele krydres med salt og peber.
1 dåse flåede tomater og
1 dåse tomatpure tilsættes.
4 store fed hvidløg hakkes og kommes i.
Det hele krydres med:
Oregano, Salt, Peber, Chilipulver, Karry, Basilikum, masser af paprika og lidt sukker.
Lad det småsimre. Gerne lang tid. Smagen er først helt rund og fordelt efter 2-3 timer.
Tilsæt majs og røde Kidney bønner og lad det simre ½ time yderligere.
10 min inden servering tilsættes noget Ketchup, så eddiken heri ikke når at forsvinde helt.
Det serveres med friskbagt flüte og hvidløgssmør.
Udlånt af Finlytteren.....
(Og tak til macwerk for det dialektiske signal.)
Indlægaf Kristian » fre apr 12, 2013 09:15
ZIG skrev: for jeg synes, at Nerds er blevet et meget kedeligt sted, hvor der egentlig ikke sker noget.
Nerds vil ihvertfald blive meget mere kedeligt hvis du ikke var her.  :wink:
Indlægaf Kristian » fre apr 12, 2013 11:09
fand en nye profil pic for dig Gurdet
Indlægaf dreamz » lør apr 13, 2013 11:17
ZIG skrev:Det var så det.
i) En handleplan
iii) Evidens
Handleplan
Behandlingsplan
Evidens
Læs denne artikel:
2 Peberfrugter,
Jeg har jo egentligt trukket mig tilbage i min postmodernistiske tilstand af selvransagelse, derfor kun dette: ZIG har åbenbart en forkærlighed for økonomer. Senest ovenikøbet en nobelpristager, og ZIG forsøger på  bedste sokratesk facon med Aumann's teorier at overbevise mig om, at enighed kan opnås såfrem begge parter har samme information til rådighed.
Nu deltager jeg sjældent i debatter med det formål at opnå enighed, og mener derved ikke, at enighed er et mål i sig selv.
Og hvad chili con carne angår, kunne jeg aldrig drømme om at servere denne sublime ret uden brug af spidskommen.
Og hvad hører jeg så nu? Ingenting; det er jo et led i selvransagelsen, Men min datter spiller med største fornøjelse hendes store idoler, One Direction. Kan ikke anbefales.
Indlægaf Kristian » søn apr 14, 2013 12:02
gurdet skrev:Reggae...? Det har jeg ikke noget af.
hva Hvad HVAD?
http://www.youtube.com/watch?v=UpV_RQTBBrM
dub smack
Når det er gørt så kan vi begynde igen  :D
LKJ, Linton Kwesi Johnson en af mine favoriter. Udover forces of victory så er et par andre som er "must buy" hvis du kan lige denne fine musik.
Dread beat and blood
Bass Culture
disse 2 og forces of victory er absolut noget man skal ha i samlingen inden for reggage
Så er det Michael Smith
Anden en meget politisk dub poet som ble dræpt i 80 tallet.
Men han nåede kun 1 plade "Mi Cyaan Believe It" master piece efter min mening :)
http://www.youtube.com/watch?v=psqxApMbjKc
http://www.youtube.com/watch?v=3TdZckFIOe4
følger mig meget heldig at have denne på vinyl
Mi Cyaan Believe It
Og anden stor dub poet Mutabaruka.
Nogle gang vanskeligt at finde frem i hans musik men der findes guld imellem.
Meanwhile mens du drikker kaffen færdig så er det Icereggae
http://www.youtube.com/watch?v=x6dhmooUyWE
Indlægaf Kristian » søn apr 14, 2013 16:31
Selvom den fineste hifi butik i scandinavia findes i samme gade og jeg bor i så er min hifi interesse helt minimum disse dagene.
renaissance audio
der findes meget forskellig udstyr der
horn og wisdom
men en tur på Bergen Kaffebrenneri og lidt altec for mit smil altid op
altec
Så er det altid fint at komme hjem igen nyde godt kaffe og lidt country funk
Indlægaf Kristian » man apr 15, 2013 08:54
vi forsætter med MU med Jeff Cotton som spillede med beefheart på trout pladen og Merrell Fankhauser.
the first album
http://www.youtube.com/watch?v=hDAgGNH62dg
Indlægaf gurdet » man apr 15, 2013 09:01
hva Hvad HVAD?
dub smack
Me no listen before, Massa, but me will listen now!
Har du fingeren på reggaepulsen i dag, Kristian?
Jeg er i mellemtiden taget til Mali:
Rokia Traoré: Wanita (2000)
Meget luftigt og smukt, men med rødderne i traditionel, vestafrikansk musik. Anbefales!
Indlægaf gurdet » man apr 15, 2013 09:11
The Fall -
Jeg har efterhånden nogle stykker af deres albums:
Hex Enduction Hour (1982)
Cerebral Caustic (1995)
The Unutterable (2000)
The Real New Fall LP (2004)
Your Future Our Clutter (2010)
Min favorit pt:
The Fall: The Real New Fall LP (formerly Country On The Click) (2004)
Det er den amerikanske udgave, jeg har, et par numre er vist andre mix og rækkefølgen af numrene er anderledes.
Indlægaf Kristian » man apr 15, 2013 09:12
gurdet skrev:
hva Hvad HVAD?
dub smack
Nej kan ikke sige at jeg har fingeren på reggaepulsen idag, jeg har vært på reggae festival hvert år nu i nogle år men der er ikke så meget nyt. Stadigvæk er det Roots som gælder http://www.youtube.com/watch?feature=endscreen&v=gxv6yb4uiYg&NR=1
Synes meget af det nyere reggae er alt for meget pop, men ville være fint at finde noget som slår igennem
Indlægaf Kristian » man apr 15, 2013 09:21
Kristian skrev:
gurdet skrev:
hva Hvad HVAD?
dub smack
fine toner indenfor dub, Jamie Saft
http://www.youtube.com/watch?v=LTjJPsXOpZk
Rigtig dugtig musikant som spiller en del exp.jazz
Indlægaf Kristian » man apr 15, 2013 11:19
Jimi Tenor kører i baggrund
Outta space og tesla
