Audio PC med Audiophile Optimizer?
Indlægaf DJakob » tors feb 19, 2015 21:52
Beskrivelse fra hjemmesiden. Nogen der har erfaring med Windows server 2012R2 kombineret med Audiophile Optimizer?
Use Windows Server 2012 R2 as operating system for your high-end audio computer, optimize it with the AudiophileOptimizer and experience analog-like sound as you have never heard it before on a computer based audio system. Learn how to set up your own high-end audio computer by simply following the free PDF guide.
Windows Server 2012 R2 and AudiophileOptimizer works very well together with JRiver Media Center, JPLAY, HQPlayer, Foobar2000, MQn Player, Spotify, Qobuz, WiMP, Logitech Media Server, Acourate Convolver, dBpoweramp and many others.
Windows Server operating systems offers the ability to completely remove the desktop environment. A Windows Server 2012 or 2012 R2 system in core mode, fully optimized with the AudiophileOptimizer, runs only 5 to 7 services and about 15 to 20 processes. Almost 150 unnecessary drivers and services are disabled, resulting in the optimal platform for ultra high-end audio reproduction. Over 300 additional modifications also benefit various elements of the operating system including priority scheduling, CPU modes and the file system, all of which greatly improve sound quality. The result is so enjoyable, so detailed, and so compelling that you simply must hear it for yourself.
A typical Windows operating system (Windows 7, Windows 8.1, etc.) has about 50 to 100 processes and about 500 to 1000 or more threads all running at the same time. The CPU is involved in every single thread and process and, unfortunately, all of this processing must take place in real-time, resulting in jitter. By dramatically reducing the number of processes and threads run by your CPU, your music server will greatly minimize noise and jitter, allowing for a far more accurate and natural sound.
Highend-AudioPC offers a sonically unlimited trial version of the AudiophileOptimizer which is combined with a 14-day money back guarantee. You have no risk at all, get in CONTACT to learn in detail how the 14-day trial works.
Det ser forholdsvis nemt ud, hvis man bare følger deres meget lange og detaljerede guide. Er der nogen herinde der har erfaring med dette?
Deres hjemmeside: http://www.highend-audiopc.com/optimizer.html
Djakob
DJakob
Geografisk sted: Kbh. V
Re: Audio PC med Audiophile Optimizer?
Indlægaf DJakob » søn feb 22, 2015 20:23
Er der nogen der kunne tænke sig at komme med en objektiv vurdering, selvom de måske ikke har nogen praksiserfaringer?
Djakob
DJakob
Indlægaf daniels » man feb 23, 2015 13:12
Det kan du tro  :D
Jeg har testet flere forskellige styresystemer (Linux, win7, win8, win8.1, Server2012), og jeg kan ikke konkludere at der skulle være lydmæssige forskelle på de forskellige systemer - når man har trimmet dem bare en smule og bruger en fornuftig player.
Jeg kunne godt tænke mig en forklaring/teori på hvorfor dette skulle betyde noget i en computer:
"50 to 100 processes and about 500 to 1000 or more threads all running at the same time"
Og hvad der præcist er det skulle gøre ved lydsignalet (jitter?)
Bare en nogenlunde logisk forklaring...
Jeg har kørt Audiophile Optimizer på min gamle win7 maskine med JPlay, og det gav ikke umiddelbart nogen forbedring - til gengæld fik jeg en række problemer med netværksadgang og lignende - det fik jeg dog løst.
Så jeg er absolut ikke solgt... Endnu  :wink:
daniels
Indlægaf digital_thor » man feb 23, 2015 18:02
Enig med Daniel her.
Har også prøvet en del frem og tilbage med både linux og windows, med diverse usb til spdif convertere. Og så længe windows er tøjlet ordenligt, så ikke dens lydkernel blander sig. Så er forskellen ikke ret stor. Jeg bruger dog linux, fordi det kan koges ned til næsten ingenting og kører på en meget simpel hardware, som f.eks Raspberry pi. Hvilket er min fortrukne vej, da jeg personligt syntes at linux er nemmere at have med at gøre.
At jeg så også er lidt sparsomlig og fik noget god starthjælp til at komme i gang med linux - betyder nok også lidt for mit valg  :wink:
digital_thor
Indlægaf DJakob » ons feb 25, 2015 16:34
Meget interessant læsning fra jer begge.
Har i erfaringer med om Win 8.1 vs 7 er bedre lydmæssigt og ikke mindst opsætningsmæssig?
Jeg har stadig svært ved at vænne mig til Win 8.1, det funger ligsom ikke helt for mig.
Måske fordi jeg kun roder med 8.1 lejlighedsvis og ret perifert på mit arbejde.
Djakob
DJakob
Indlægaf digital_thor » ons feb 25, 2015 21:41
nope.... men hvis det er lidt svært at vende dig til 8.1 i forhold til 7. Så kan du jo lege lidt med classicshell:
http://classicshell.net/
Så komme det hele til at ligne windows 7 igen - pånær lige nogle ganske få ting, som er af mindre betydning IMO. Men bestemt noget jeg anbefaler til folk der lige har lidt svært ved at vende sig til deres nyindkøbte bærbar, som de ikke kan finde hoved og hale i - det er jo som sagt bare en brugeflade. Men indrømmet jeg fortrækker også den lidt mere gammeldags facon. Ønsker en PC og ikke en iphone der har "humpet" et shopping/medie helvede. Bevares - meget kan slås fra. Men det handler jo om at tjene penge, hvilket nok også er derfor at jeg fortrækker linux - som så lige har lidt amazon på deres ubuntu...... meeen ingen er jo perfekt  :?
Har pt ikke leget med om 8.1 skulle virke bedre end 7 til lyd.
Men en hurtig test på en bærbar med hiface 2 tilsluttes, hvor jeg så have både windows 7 og linux mint - ja der var der ikke meget forskel. Men igen, det var en hurtig test.
I sidste ende ville jeg nok tænke lidt over hvad du ønsker af brugervenlighed , muligheder og ydelse. Lav en prioriteringsliste med hvad der vigtigst for dig. Dernæst er det meget nemmere at snævre mulighederne ind  :wink:
digital_thor
Indlægaf daniels » tors feb 26, 2015 09:03
Der er ikke de store forskelle på lydindstillinger på Win7 og Win8/8.1.
Det er de samme ting man skal gøre.
Jeg er selv meget glad for Win8.1 - Det er jo også en helt anden snak, for det handler jo mere om man er omstillingsparat til noget nyt  :wink:
Jeg har ikke oplevet nogen ændringer i lyden mellem de to systemer. Men efter mine egne teorier (og erfaringer), bør der heller ikke være forskel.
Hvis du bruger en memory player til at afspille din musik (f.eks. JRiver), så vil megen af al den snak om jitter i selve computeren være minimeret.
Undersøger man det tekniske, vil man se at den jitter der kan opstå i en computer, er meget mindre end hvad der opstår i en CD-afspiller. Og var/er de så ringe?
Jeg synes selv streamer-snakken er blevet afsporet af magi og voodoo opfattelser af digitalteknik (digitalis som nogen vil kalde det  :) ) - men det er jo meget kendetegnet ved hele HiFi-hobbyen  :wink:
daniels
Indlægaf DJakob » lør feb 28, 2015 12:02
Hej Daniels :-)
Ved du om der ligger nogle guides til hvordan man bedst muligt trimmer sin win7/8.1 for alt det overflødige?
God Wee  :mrgreen:
Djakob
DJakob
Indlægaf daniels » søn mar 01, 2015 11:22
DJakob skrev:
Hej Daniels :-)
God Wee  :mrgreen:
Har ikke lige nogen på hånden, men det ligger egentlig bare under lydegenskaber, at man lige slår diverse rumeffekter fra og sætter bitdybde og samplerate op til max. Ikke så meget mere i det.
Drivere til lydkortet er selvfølgelig også en god ide at have opdateret.
daniels
Indlægaf msp99 » man mar 02, 2015 21:13
Dobbeltpost
Senest rettet af msp99 man mar 02, 2015 21:15, rettet i alt 1 gang.
msp99
Tilmeldt: tirs feb 22, 2011 21:26
Hej i tråden, mener at du skrev Daniel at du brugte Jplay—det gør jeg også, syntes det gav rigtigt meget, jeg bruger det i ”hibernation” mode—så skulle programmet lukke ned for det meste.
Et er helt sikkert, det betyder meget for lyden.
Hilsen Morten
msp99
Indlægaf daniels » tirs mar 03, 2015 14:00
msp99 skrev:Hej i tråden, mener at du skrev Daniel at du brugte Jplay—det gør jeg også, syntes det gav rigtigt meget, jeg bruger det i ”hibernation” mode—så skulle programmet lukke ned for det meste.
Hilsen Morten
Jeg har gjort det tidligere, men synes ikke det gav noget.
Skal lige noteres at jeg bruger et SotM USB kort og har gjort en del ud af strømleverancen.
Jeg skifter til lineær strømforsyning til både SotM kortet og til computeren inden så længe - så må vi se om det giver noget.
daniels
Indlægaf DJakob » ons mar 04, 2015 20:32
Er der nogen der ved om det er forskel lydmæssigt om man vælger Windows 8.1 i 32 eller 64 bit?
Er der fordele / ulemper?
Djakob
DJakob
Indlægaf digital_thor » ons mar 04, 2015 21:21
Arh... jeg tvivler på at det gør forskel for lyden. Med 64 bit kan du jo bare allokere mere hukommelse... dvs krydse den famøse grænse på ca 3.5GB for den samlede hukommelse i systemet.
Så hvis man mener at mere ram.... f,eks 8 GB er bedre end 4 eller 2, til en streamerløsning, så er er det jo nødvendigt med 64bit.
Men der er jo også snak om at "less is more".
Så det er måske derfor at mit streamer setup er godt i mine øre, da det jo er en lille bitte CPU med et meget simpelt system(raspberry pi).
digital_thor
Indlægaf Play-mate » søn mar 08, 2015 13:34
Der er masser af interesse for computer audio og ganske mange muligheder for at kombinere tingene. Dog må man sige at det kæmpe udbud, og især hifi branchens indlæg med streaming-løsninger, gør det ret vanskeligt at finde op og ned på det hele.
En af de bedste kilder til at blive klogere, er Vincent Kaar´s webside om emnet :
http://www.thewelltemperedcomputer.com/index.html
Uden reklamer og uden at pådutte nogen kommercielle interesser, er dette nok det bedste sted at starte.
JPlayer (og Audiophile Optimizer) er egentlig den kommercielle aflægger af det oprindelige cMP2 (http://www.cicsmemoryplayer.com) projekt, som tidligt introducerede RAM-hukommelse som central feature.
JPlayer projektet startede som en "nemmere" løsning end cMP2, men som tiden er gået, er det blevet mere og mere kompliceret.
Det er særdeles vigtigt at skelne mellem streaming- og computeraudio, fordi det protokol (eller kabel-standard) der skal få bytes igennem til DAC´en, kan deles i enten et kontinuerligt digitalt signal (f.eks. S/PDIF), eller også som en dataforbindelse med buffers (f.eks. USB).
Derfor skal man være forsigtig med ambitionerne om at få en computer til at agere bindeled mellem en streamingtjeneste (f.eks. Spotify) og sit hifi udstyr.
Det er muligt at et 64 bit operativsystem er fordelagtigt når der skal konverteres fra DSD til PCM, eller når DSD er den native standard for DAC´en, men ellers er  32 bit helt tilstrækkeligt.
Win 7 er mindre kompliceret end Win 8 at tune til audiobrug, og Windows egne audio-protokoller bør man alligevel undgå, så Win 7 er at foretrække.
Hilsen Leif
Play-mate
Tilmeldt: ons mar 04, 2015 11:48
