Analogueman skrev:Jeg drillede kun ... jeg er velforsynet med espressomaskiner med både PID, E61 bryggehoved og cirkulationspumpe, så lidt espressoerfaring har jeg da.
Nu mangler jeg kun at forsøge at brygge en espresso med friskpresset vand
PS. 15 bar er godt nok højt?
Min kører med 15 bars pumpetryk, og det kører de fleste maskiner vel med, nogen med hele 19 bar.
9 bar +/- 1 bar er den Italienske standard, sat af Istituto Nazionale Espresso Italiano
Men nu er tryk jo ikke alt, selvfølgelig, når vi taler om kunsten; Espresso, her er en mening fra en espresso guru:
15 bars of pressure is considered the sweet spot for creating great tasting shots.
Too little pressure will leave you with an under-concentrated brew; too much pressure and you'll be forcing down an over-extracted, bitter shot.
The industry standard is 9 bars of pressure. While 9 bars of pressure can create a decent espresso, 15 bars make the finest brews…. or will it?
Not necessarily. This is a misconception.
The more bars you have does not mean the better quality your espresso shot will be – this is merely persuasive marketing resulting from the whole “bigger is better” society that we live in. (Dette kan i særdeleshed også gælde for pladetallerkner).
More pressure will
HELP you in making a better quality shot, yes, however there is more too it than simply adding more pressure.
