The Ultimate Audiophile Reference disk by Sheffield Labs - in the very rare XRCD Extended Resolution format - NEW - SEALED The is the disk that will show exactly how good your system is - end of story. If your system is up to the task, the incredible dynamics and resolution will absolutely floor you.(and your guests) First 75.00 takes it. (you will not see another one of these) Descriptive text below.. ________________________________________ Great Sounding Music for Testing and Evaluating Your Sound System! Absolutely the best sounding rock and roll record ever made. - The Absolute Sound. "The sonic fidelity of the Sheffield Drum record is enthralling, and its value for learning about your system makes it a must." - The International Audio Review "...Unstrained, crystalline clarity ...incredible gut-shaking impact...the sound is beyond belief." -The Sensible Sound The four rock instrumentals on The Sheffield Drum and Track Record feature Robbie Buchanan and James Newton Howard, keyboards, Lennie Castro, percussion, Nathan East, bass, Mike Landau, guitar, and Carlos Vega, drums. These are followed by two famous drummers, individually, in free solo improvisations. They are Ron Tutt, most well known as Elvis Presley's drummer, and Jim Keltner, former member of Gary Lewis and the Playboys and musical collaborator with John Lennon, George Harrison, Ringo Starr, Bob Dylan and many others. The Sheffield Drum Record: (Doug Sax, producer. Bill Schnee, producer, engineer. Lincoln Mayorga, executive producer. Steve Haselton, chief engineer for Sheffield Lab. Recorded December 15 and 17, 1980, Sheffield Lab Studios at MGM, Culver City. California.) Ron Tutt is one of the most versatile of musicians, admired as both a rock and jazz drummer, and active in recording for television and motion pictures as well as pop records. Ron is best known for the ten years he worked as Elvis Presley's drummer for records and concerts. Drummer Jim Keltner was an original member of Gary Lewis and The Playboys. Jim participated in many Sheffield recordings, providing the rhythmic propulsion for "Pressure Cooker" and the series of "Distinguished Colleagues" albums. He has recorded with dozens of major artists including John Lennon, George Harrison, Ringo Starr, Bob Dylan, and Bette Midler. Bill Schnee has earned acclaim both as an engineer and a producer. He has produced albums by such artists as Boz Scaggs and Pablo Cruise. Winner of a Grammy Award for engineering an album by Steely Dan, Bill has also engineered for Barbra Streisand, Ringo Starr, and Carly Simon, and received Grammy nominations for five previous Sheffield Lab recordings. A drum set is ideal for critical evaluation of a high fidelity system. Sheffield Labs has recorded two extraordinary drummers, individually in free improvisations. this record is a "high resolution test source" and as such is extremely demanding. It will challenge every component in your playback chain. At a reasonable average listening level, some amplifiers may produce clipping, as the peak factors are very great. Adjust your volume accordingly. When comparing different components, Sheffield Labs suggests you try extended listening in addition to rapid "A-B' tests which can sometimes lead you astray. The microphones used included two overhead mikes which were two feet above the drum set. A third microphone was positioned on the floor in front of the kick drum. On Ron Tutt's drum set an additional fourth microphone was used on his snare drum. His snare is a specifically tuned for rock recording and should sound "thicker" and have less "crack" than the snare used by Jim Keltner. Jim used a concert snare, such as would be used in a symphony orchestra. His snare has incredible impact and a much brighter sound. Listen for the ring off of the room after his snare is hit. There was no artificial reverberation used to make this record; however you will hear a definite amount of "room decay" in Sheffield Lab's studio, MGM's Stage One, a room designed to record a large orchestra. If yo hear a difference in the amount of "room" between two different components, the one which is giving you more "room" is more accurate. Low level information is the most easily lost in the playback chain as well as being the hardest to capture in the recording room. The kick drum for both drummers was recorded "well up in the set" to have as much impact as possible. Its wide response is most telling in evaluating transient response and phase linearity of loudspeakers. the microphone was placed to pick up the pat of the beater as well as the low frequency of the drum. Ron's kick drum has more low bottom than Jim's. Played correctly, the kick drum should be "fat" with good impulse and attack, not a "think" sound with mostly attack. Ron's tom-toms, which are wood Ludwigs, are quite even and on the dark side. They are undampened. In certain sections, you will hear one keep ringing after it is hit. A system which allows this ring to be heard and not die off is reproducing what is on the record. Ron's Zildjian cymbals are sweeter sounding with less mid-range and more "silk" than Jim's. They have a preponderance of energy around 8-10khz and will sound a little "hashier" than Ron's. Jim also plays a whistle, a small sleigh bell which he moves between the overhead mikes, a small rattle, and a triangle which he plays while on the kick drum and high hat. He also creates an unusual effect by scraping the thick end of a drum stick across a symbol. Notice when Jim switches from drum sticks to mallets and brushes. The accurate reproduction of a drum set is a severe test for all components in a system and will show the advantages of speakers and amplifiers with wide dynamic range the ability to handle transients. J. Peter Moncrieff, editor of the International Audio Review, said, "A woofer can be sluggish or poorly dampened, and you'd never hear anything wrong with a pipe organ pedal note, but a kick drum transient would sound unnatural. 'The Sheffield Drum Record' will tell you about the quality of bass your loudspeaker can put out and will do so within seconds..." Ja her lyder det ikke mindre end formidabelt, så et eller andet må jeg ha' gjort rigtigt
Disse to tromme tracks (Jim Keltner - Ron Tutt) skiller virkelig fårene fra bukkene og der er bare ikke nogle "normale" højtalere der kan gengive det realistisk, i hvert fald ikke som jeg forstår/hører musik.
