Buchardts vennetråd
I dette forum kan specifikke mærkers venner, fans og beundrere skrive frit, også sammen med forhandlere og importører af det enkelte mærke. Der henstilles til, at tråde i denne kategori får et "-vennetråd" efter mærkets navn, eks "Thule vennetråd". Den enkelte vennetråd skal respekteres, og det anses som uskik eks. at begynde at diskuterer Dali i en Dynaudio vennetråd. Branchemedlemmer har langt mere frie hænder i en vennetråd, omend reklame og ros bør holdes inde for rimelighedens grænser. Indlæg, der er emne/producent uvedkommende, betragtes som spam og fjernes uden advarsel.
Re: Buchardts vennetråd
Indlægaf Ning » søn dec 29, 2019 16:46
Tak for tippet :D dem kendte jeg ikke (som gruppe)
Har hørt /set Nathan East til et par Toto koncerter.
Man kan godt fornemme der er kælet for optagelsen.
Ning
Tilmeldt: tirs apr 01, 2014 16:32
Indlægaf P.H. » tors jan 16, 2020 08:01
Spændende nyt fra Buchardt:
PM#1
From a Buchardt rep on Facebook (This was in response to the suggestion they should come out with an active speaker.):
We are soon ready with some actives yes. But they aim to hit way above the xeo series, so the prices does as well.
A500 : Its close to the design of the S400 and then not really. It looks like it with the waveguide, it's just on top now (we can do time alignment in the DSP here). The cabinet is a bit deeper (4 centimeters). The big change is that we here use closed cabinets. We have one woofer in the front, and one in the back over the active system. Each woofer is in its own cabinet inside so we can time aligned the back woofer. They don't have much space to work with so we need a ton of power for them. Here we have 3 x 150 w of some brand new class d chips from Texas Instruments and a powerful power supply to support them. We have a high quality DSP and the CS4398 DAC in each speaker as well. They can be connected via WISA to our hub and remote. You can use any WISA receiver for that matter so the system is very flexible. You can also simply connect them via XLR to your own preamp and run them analog. But using our hub, you will also have the ability to use our Room correction, which is a topic by itself. But in short, it's made directly to handle the issues in the bass caused by the room (sub 250hz) and it touches nothing else! I really can't emphasize enough how fantastic this actually works, and it's very easy to setup as well and measure your room with the mic.
A700 floorstander : All the same jazz, just with 4 x 150 w amps and a 3.5 way design instead of a 2.5 way or 3 way depending on the configuration of the A500. This will have waveguide, 6" midrange, 2 x 6" woofers in front (17-200hz) and on the back 2 x 6" woofers (17-100hz). Still pretty elegant and compact design, but with a ton of power!
We have made our own high quality alu remote for the system. It's a very nice remote with led indication on volume and what channel is selected. The hub is a small black box where you would connect everything to. of inputs it has 1 x analog 3 x optics 1 x coax 1 x USB 1 x Mini Jack 1 x HDMI. To this it has built in Chromecast, Airplay, Spotify connect and Bluetooth. So its a complete system.
A500 would be 3500 euro including VAT, TAX, import fees and worldwide shipping.
A700 would be 5000 euro including VAT, TAX, import fees and worldwide shipping.
We do also have plans for a cheaper active that is more in the competition of the xeo series, cheaper than the s400 as well.
Emm Labs Dac2X
BAT VK52SE
BAT VK255SE
Buchardt s400, Dynaudio 6
NLE, Swoboda, Acoustic Revive
Grado GS1000
P.H.
Indlægaf Otto J » tors jan 16, 2020 13:15
*HOST*silverback*HOST*
Mvh. Otto
Otto J
Indlægaf Ning » tors jan 23, 2020 11:58
Otto J skrev:*HOST*silverback*HOST*
Der er vel ikke noget mærkeligt i at de bruger den forstærker.. Det er vel det der er meningen med sådan et produkt
Ning
Indlægaf Madsbuchardt » man feb 10, 2020 16:39
Det er samme platform som bliver brugt i silverback. Dog er vores med andre dele, som 3 x så mange kræfter og bedre dacs, Så den er noget større hvis man skulle tage dem ud.
Vi startede selv udviklingen med den platform System audio bruger idag. Vores aktive var det første produkt, denne platform blev testet med. Vi valgte dog at vente på en større og mere kraftige model blev lavet der var tilpasset vores behov, da vi havde brug for mere power pga. vores enheder og typisk mindre kabinetter sammenlignet med SA.
System audio og Buchardt bliver næppe de eneste pÃ¥ denne platform heller, men er stolt af at dele den med Silverbacks. Jeg vil dog sige, at selvom de bruger samme platform i bund og grund, sÃ¥ er højttalerne slet ikke tunet ens. Buchardt lyder af Buchardt, og SA som SA plejer. Det er jo en smagssag til hvad man bedst kan lide.
Det er en rigtig god og gennemarbejdet platform, som tilbyder en del mere end hvad mange konkurrenter gør. Som et mindre firma, ville det være tåbeligt at smide 20-30 millioner efter udvikling af egen platform. Denne platform er alligevel skræddersyet til os, da det er A500 og A700 den i bund og grund er lavet til. Dog tilbydes den også til andre firmaer fremover :)
Hilsen Mads Buchardt - Buchardt Audio
Madsbuchardt
Tilmeldt: søn okt 19, 2014 21:26
Indlægaf Ning » man feb 10, 2020 21:48
Hej Mads
Tak for info, mente nok jeg havde læst noget i den retning i et eller andet (amerikansk?) forum
Kan du afsløre hvad i vil spille på til Sound Society... Bliver det muligt at høre gulvhøjttalere også, eller satser du kun på A500 i denne omgang?
Mvh Henning
Ning
Indlægaf sigma6 » fre maj 08, 2020 12:44
sigma6
Indlægaf Ning » fre maj 08, 2020 21:11
Sigma, har du læst det hele? Også det han skriver efter konklusionen?
Og som jeg læser det, sÃ¥ starter han med at mÃ¥le pÃ¥ dem,  og finder en
unormalitet(?) han ikke kan distrahere fra? Og så går der 30 sider med debat derom.. Også med Mads..
Ning
Indlægaf P.H. » lør maj 09, 2020 19:15
Ning skrev:Sigma, har du læst det hele? Også det han skriver efter konklusionen?
Tja, for meget information kan være en ulempe. Slagteren spiser heller ikke pølser - han ved jo hvad de indeholder :lol:
Den pågældende diskussion synes umiddelbart at have karakter af "flueknepperi" for viderekomne.
Emm Labs Dac2X
BAT VK52SE
BAT VK255SE
Grado GS1000
P.H.
Indlægaf P.H. » søn okt 11, 2020 14:51
HÃ¥ber lidt pÃ¥ en fremtidig passiv model 700. Trods de aktive modellers utvivlsomme dyder, bryder mange hifi-nørder sig nok ikke sÃ¥ meget om at  være bundet af firmaets forvalgte for-/effektforstærker og DAC, hvilket en af produkternes i øvrigt begejstrede anmeldere ogsÃ¥ bemærkede i anmeldelsen af A500.
Emm Labs Dac2X
BAT VK52SE
BAT VK255SE
Grado GS1000
P.H.
Indlægaf Frankie » man okt 12, 2020 13:29
[quote="P.H."]HÃ¥ber lidt pÃ¥ en fremtidig passiv model 700. Trods de aktive modellers utvivlsomme dyder, bryder mange hifi-nørder sig nok ikke sÃ¥ meget om at  være bundet af firmaets forvalgte for-/effektforstærker og DAC, hvilket en af produkternes i øvrigt begejstrede anmeldere ogsÃ¥ bemærkede i anmeldelsen af A500.[/quote]
Er snart 60 og alligevel vover jeg pelsen, efter 45 Ã¥r med hifi  8)
Efter mange behagelige samtaler med Mads er jeg knapt sÃ¥ fordomsfuld som jeg var i starten ..... et stort skridt i min alder  :lol: men det skal prøves !
Har valgt A700 sÃ¥ mÃ¥ vi se / høre om det spiller  :)
Frankie
Tilmeldt: ons dec 19, 2007 17:40
Indlægaf P.H. » tors okt 15, 2020 11:01
Aflæg gerne rapport, Frankie :D
Emm Labs Dac2X
BAT VK52SE
BAT VK255SE
Grado GS1000
P.H.
Indlægaf Frankie » tors okt 15, 2020 12:49
[quote="P.H."]Aflæg gerne rapport, Frankie :D[/quote]
Gør jeg .... hÃ¥ber at modtage A700 i løbet af uge 46  :)
Frankie
Indlægaf DanishCanadian » lør okt 31, 2020 22:03
Så troede jeg lige at jeg skulle over til Århus for at høre et par S400 i forrige uge. Men Mads var så venlig at sende mig en mail om at han flytter showroom til Silkeborg. ØV!
Jeg har i dag et sæt Dali Opticon 6 gulvhøjtalere og overvejer at skifte dem ud med et sæt S400. Ville dog rigtig gerne høre dem inden. Jeg kommer nok ikke lige til Silkeborg i nær fremtid.
Jeg har en NAD C368. Nogen der ved om den vil være tilstrækkeligt til et par S400?
Venlig hilsen
Chris
DanishCanadian
Tilmeldt: man okt 19, 2020 07:35
Indlægaf P.H. » lør okt 31, 2020 22:44
Venlig hilsen
Chris
Burde overhovedet ikke være noget problem. :)
Emm Labs Dac2X
BAT VK52SE
BAT VK255SE
Grado GS1000
P.H.
Tilbage til Venneforum
