Søger god 2w modstand
Re: Søger god 2w modstand
Indlægaf Maleren » søn apr 26, 2020 22:23
En lille "ahaaa" omkring støj i Acurus A250, og som har optaget mig en del efterfølgende.
Citat fra en tråd jeg har på AK, skrevet af medlem; Mondialfan
"I got curious as to what is causing the poorer distortion performance in the A250 Left channel versus the right channel in the amps that I've worked on so I started doing some experiments on an A250 pcb this weekend. Conclusion, the A250 board has a design/layout flaw which results in the poor distortion performance when the board is configured in the L-ch configuration. It appears that the output Zobel network is positioned too closely to the thermal switch circuit and that is causing distortion in the diff input current sources.
I reconfigured my left channel board to move the Zobel to the opposite side and 1kHz distortion dropped about -3dB and for 20kHz at powers above 100W distortion dropped by -6dB or more. I had a before/after graph and lost it somehow. I think I oversaved another file over it and didn't realize it until later. Anyway this design issue was corrected in the later gen Acurus products, A150, A200, etc. Their distortion performance was better by as much as -6dB than the first gen A250's. Not to mention that the later gen Acurus amplifiers channel to channel performance matched much better.
Knielsen, I'd highly recommend that if you're going to move forward on creating your own boards that you try to adopt some of the layout tricks from the later A200 board. I have a couple of close-up images of the L & R boards. The right board picture was after I began upgrading it so the extra rail decoupling caps were already added.
It appears that Mondial realized their first gen design screwup and didn't try to create one board for both channels in the later amps. They all had dedicated R & L channel boards. You'll notice that the speaker Zobel network for the newer A200boards is put on the extreme end of the board right by where the speaker output wire is. Also you'll notice that they put the T1 thermal switch on the opposite side of the board from the speaker out & Zobel. This layout is very similar to the A250's board when it is configured as a R-ch board so obviously they realized which side of the earlier amp had the better performance and figured out where the problem was in their design."
Maleren
Indlægaf Kaj. » man apr 27, 2020 05:55
Indlægget er en værdifuld bekræftelse af vigtigheden i den rette kabelføring og forbindelsesvejen mellem komponenterne. Selv små og tilsyneladende ligegyldige ting har indflydelse på apparaternes performance.  :wink:
Indlægaf Maleren » man apr 27, 2020 08:16
Jeg har købt en nyere A200 med de nye print der refereres til for at høre/se "what the fuzz is all about!" :lol:
Jeg har tidligere været meget påståelig omkring A200 og dets niveau, men må nok æde min egen undtagelser.
Jeg lyttede på den for første gang i går, efter den havde stået i en 14-dages tid i venteposition til tiden var til et stykke musik, og ud af boksen spiller den langt mere homogen end den tidligere A250-model (umodificeret naturligvis)
Hvorvidt jeg beholder A200 er jeg ikke kommet frem til endnu, men den har stort potentiale, det står klart.
Edit: "Jeg har tidligere været meget påståelig omkring A200 og dets niveau" ------ Dette var basseret på at de tekniske løsninger ikke gav anledning til at den skulle være så meget bedre end forgængeren. Sandheden lå i duallayer printet til min overraskelse :wink:
Maleren
Indlægaf Maleren » man maj 11, 2020 16:13
Poster lige denne jeg har gang i.... Lavet efter alle kunstens regler (og budget naturligvis) og med tilhørende massefylde i de kabler der benyttes efterfølgende.
A250
Denne Acurus skal også have fixet den "blinkende kontakt". Det tager ca 2timer for en øvet at lave dioden, så sæt 3-4timer af, så der ikke stresses om at blive færdig. Rygterne vil vide; det er ikke noget problem at skille kontakten ad, det sjove er at samle den igen uden at ødelægge noget  :!:
Mvh Kåre
Senest rettet af Maleren tors maj 14, 2020 15:27, rettet i alt 1 gang.
Maleren
Indlægaf Maleren » tors maj 14, 2020 15:27
En afslutning skal der til, og finder det passende med de sidste billeder der er taget af forstærkeren jf denne tråd plus lidt løst efterfølgende.
Regards
PS: Kim (Admin), vil du tjekke din mail
Maleren
Indlægaf i-anden » tors maj 14, 2020 15:34
Kåre, hvis du laver være med at logge på i 3 mdr så lukkes din profil automatisk  :wink:
i-anden
Indlægaf Maleren » tors maj 14, 2020 15:55
i-anden skrev:Kåre, hvis du laver være med at logge på i 3 mdr så lukkes din profil automatisk  :wink:
Hmmm jaaaa jooooo..... Har nu skrevet med flere her inde det sidste årti som ikke er aktive længere, men profilen er åben.
Maleren
Indlægaf i-anden » tors maj 14, 2020 15:58
Det er vist sjældent at man kan se på profilen at den er lukket, det mener jeg ikke bliver skrevet ved den  :wink:
i-anden
Indlægaf Maleren » tors maj 14, 2020 16:04
Lortet skal bare lukkes :lol: kom til at læse gamle mails forleden aften, og finder det passende hvis ADMIN bare ville lukke. Jeg har taget de tæsk jeg skal, kontra de private mails jeg læste......
Så Admin... LUK.
Maleren
Indlægaf i-anden » tors maj 14, 2020 16:53
Maleren skrev:Lortet skal bare lukkes :lol: kom til at læse gamle mails forleden aften, og finder det passende hvis ADMIN bare ville lukke. Jeg har taget de tæsk jeg skal, kontra de private mails jeg læste......
Så Admin... LUK.
Det lyder som om du har haft det særdeles hårdt på fora  :mrgreen:
i-anden
Indlægaf Maleren » tors maj 14, 2020 17:14
i-anden skrev:Det lyder som om du har haft det særdeles hårdt på fora  :mrgreen:
End
Maleren
Indlægaf i-anden » tirs okt 13, 2020 23:02
Den kære Lydjørgen er nu på banen igen. Denne gang har han fået lov til at blive på hifi4all under navnet Jenslyd, las os se hvor længe han kan holde raseriet nede på et rimeligt plan.
Nu venter jeg så spændt på om der er nogle på hifi4all der vil se billeder og videoer af Lydjørgen/Jenslyds setup, da det som regel for ham til at stikke halen mellem benene og fordufte som han gjorde herfra, da nogle spurgte om præcis det samme.
Det må snart være på tide at vi får lov at se hvordan det mest korrekte setup i Danmark ser ud, i stedet for konstant at læse det samme fra ham om klang, præcision, materialevalg og bla bla bla.  :roll:
i-anden
Tilbage til DIY-forstærkere
