Denon 3930 & 2930
Denon 3930 & 2930
Indlægaf Raskolnikov » lør jun 17, 2006 13:39
Der kommer nye dvdafspiller fra Denon til September. Det bliver interessant.
Både 3930 og 2930 får også HQV chippen fra den store model. Samtidig har de begge 1080p upscaling.
        Denon DVD-3930
        Teranex Realta HQV processing
        1080p upscaling
        New
          GUI on screen graphics
        MDDF(Multi-Direction
          Diagonal Filter)
          DivX
          Playback
(3.11 / 4.x / 5.x/6.0)
        DVD
        Video/DVD Audio/SACD Player with Dolby
        Digital
and DTS decoder
HDMI
        (High-Definition Multimedia Interface) for direct
          connection to a Plasma
Digital
          Link 3rd Edition & i.link for audio, both carry SACD and DVD-Audio
Finest
          available processing for film, video, graphics or mixed-mode content
Adjustable
          Chroma Delay and Level, White/Black Levels, CCS On/Off controls
Exclusive
          Denon Picture Image Correction provides for Vertical and
          Horizontal pixel enhancement
New
          ESS Vibrato "Chroma Bug Free" MPEG/DVD-Audio Decoder
Sony
          CXD-2753 Second Generation DSD Decoder
216 MHz, 4:4:4, 14 bit Video
          D/A
          Conversion
8x
          Oversampling Progressive and 16x Interlace output
Wideband
          relay switched component video outputs
Variable
          Black Level (Setup): 0 and 7.5 IRE
Passes
          below-black (PLUGE) on progressive and interlace outputs
HDMI Multi-Channel Audio Compatible, outputs with
          selectable 480p/720p/1080i /1080p output
Burr-Brown
          24-bit, 192-kHz DSD-1796 Audio
          DACs that decode PCM and DSD
          signals separately with no DSD to PCM conversion
40/60/80/100/120Hz
          crossover points with 12dB high and 24dB low pass slopes
Adjustable
          delay time and Channel Levels
Source
          Direct Mode for PCM or
SACD, bypasses Bass Management Speaker
          Configuration, but permits Channel Level and Delay Time adjustments (No
          conversion of DSD signals to PCM)
JPEG
          photo file viewer, Kodak Picture and Fujicolor CD compatible
HDCD
          decoding
AL24 Processing Plus for all 6 Channels
PCM
          and DSD Compatible IEEE-1394 Outputs, featuring exclusive DENON Clock
          Synchronized System (DCSS), a proprietary and defeatable system
Anamorphic
          Scaling for 4:3/16:9 Sets
4:3
          Squeeze and Zoom Controls
Pure
          Direct Modes to defeat unneeded portions of player for the ultimate in
          audio performance
SRS
          TruSurround
RS-232C
          and Remote in/out ports
        8MB
        Buffer to aide better layer change
        PAL
        & NTSC Progressive
        Scan
Output
        RGB
          SCART Socket
Disse lyder interssante:
Sony
PCM
          Synchronized System (DCSS), a proprietary and defeatable system , hmm er det ikke nyt?
Indlægaf Raskolnikov » søn jul 02, 2006 01:49
Mere info:
http://www.avbuzz.com/audio-video/20060 ... /index.htm
2930 får de samme dacs. som min 2200 dvs. BB 1791, men det ser ud som om at der er et nyt drev. Det ligner et pc drev...
Indlægaf Jonas Bojer » søn jul 02, 2006 06:18
hmmm hvad skal man md en DVD afspiller Tapeconnection har allerede en HD-dvd stående i butikken ,o)
Hilsen Jonas Bojer
Jonas Bojer
Geografisk sted: Odder
Indlægaf Raskolnikov » søn jul 02, 2006 19:07
Har de det?! Det må jeg lige kigge på. Altså den i Aarhus ik?
Indlægaf Raskolnikov » fre jul 28, 2006 07:02
Mere nyt:
Denon's new 1080p upscaling DVD players
Posted Jul 28th 2006 12:25AM by Darren Murph
Filed under: HDTV, Home Entertainment
If you can't make heads nor tails of the whole HD DVD / Blu-ray debacle but still want a taste of 1080p, Denon's new lineup delivers just that. Realizing some people are still waiting to see how the next-gen optical disc war pans out, Denon has unveiled three new 1080p upscaling DVD players that are marginally more affordable than its more luxurious options. Apparently Denon is marketing these units to easily fit into any custom installation by labeling each model "CI," although we can't really think of how else to install a DVD player. Regardless, the DVD-3930CI ($1,499), DVD-2930CI ($849), and DVD-1930CI ($369) all offer 1080p upconverting over HDMI and SACD / DVD-Audio playback. The DVD-3930CI sports the same Realta HQV chipset as in the DVD-5930CI, Denon Pixel Image Correction (DPIC), on-board keystone correction, and Burr-Brown PCM-1796 DACs. The mid-ranger features the Silicon Optix REON VX chipset and DPIC while the DVD-1930CI steps down to a Faroudja DCDi chipset and a more economical version of the Burr-Brown DACs. Not much has changed outside of the technical rundown, as all of the units feature Denon's subtle black styling and promise to deliver that "uncompromising quality" we've come to expect. If you need something to hold you off awhile longer before choosing an HD format, or maybe a good reason to see what you've been missing on DVD, Denon's two higher-end models can be grabbed now while the DVD-1930CI will be available in August.
DVS at 2930 nok kommer til at koste 5.k-6k og at den ikke bliver dyrer som man spekuleret...
http://www.audioholics.com/news/uploads ... Ifront.jpg
http://www.audioholics.com/news/editori ... I1080p.php
Tilbage til Surround Sound
