Hej..
Lyder denne speaker godt eller skidt... ja jeg har selv lyttet til dem og syns de lyder godt, men hvad siger målingerne??
Microphone measuring position: between tweeter and top woofer
Grille: off
Sensitivity: 88.5dB (averaged 300Hz-3kHz, 2.83V/1m)
Frequency response, 20Hz - 20kHz (measured @ 2m, plotted @ 1m)
Top curve: on-axis response
Middle curve: 15 degrees off-axis response
Bottom curve: 30 degrees off-axis response
Top curve: 45 degrees off-axis response
Middle curve: 60 degrees off-axis response
Bottom curve: 75 degrees off-axis response
| Chart 2 - Listening Window |
Listening Window, 20Hz - 20kHz (measured @ 2m, plotted @ 1m)
Response curve is an average of five measurements:
on-axis, 15 degrees left and right off-axis,
15 degrees up and down off-axis
| Chart 3 - Total Harmonic Distortion + Noise |
THD+N @ 90dB, 50Hz - 10kHz (measured @ 2m)
Top curve: frequency response @ 90dB SPL
Bottom curve: THD+N @ 90dB (50Hz - 10kHz)
Additional Measurement
THD+N @ 95dB, 50Hz - 10kHz (measured @ 2m)
Top curve: frequency response @ 95dB SPL
Bottom curve: THD+N @ 95dB (50Hz - 10kHz)
| Chart 4 - Impedance Magnitude Variation and Electrical Phase |
Impedance curve
Vertical axis: impedance
Horizontal axis: frequency
Electrical phase
Vertical axis: phase
