Jeg har et spørgsmål til denne tråd http://www.avsforum.com/avs-vb/showthread.php?t=719041
under multithreading står der følgende:
Multithreading _____________
If you have a multithreading cpu, put the avisynth.dll from the MT folder in the windows system32 folder,
and the MT.dll plugin from the MT folder into the avisynth plugin folder. Now, put MT("Script",3) using any of the script above.
Notice In the MT script, I'm using 3 threads.
It's a tweak so that dual core and Hyperthreading cpu's can distribute the work better.
It works fine on my hyperthreading cpu.
If you have a quad core, then it would look like this MT("Script",4
Nu ahr jeg hentet filerne, men hvor skal jeg ændre det? synes ikke jeg kan finde det, eller misforstår jeg det?
\René
\René
