Zorglub skrev:Art Dudley skrev en spændende testraport for noget tid siden i stereophile om det. Han kan ikke høre forskelmen syntes det er nogle rigtig gode kabler, også uden batterier.
http://stereophile.com/cables/804aq/
Ellers skriver de selv...
"DIELECTRIC-BIAS SYSTEM (patent pending): Unfortunately, because insulation stores and releases energy, it is also a “dielectric.” In a cable application, all released energy is distortion. The misnomer “break-in” is often used to describe the pronounced improvement in performance as the dielectric adapts to a charged state as the cable is used. Whenever a cable does not have a charge on it, it is re-adapting to an uncharged state; it is becoming new again.
By maintaining a 36 volt dielectric-bias, far above the voltage of delicate audio signals, the DBS system provides considerably better transparency and dynamics than is possible even from a cable in continuous use. It takes a couple of weeks for the DBS system to reach maximum performance. Since DBS battery packs are attached when Gibraltar cables are first terminated, Gibraltar will be approaching or at peak performance by the time it is installed in your system. Since there is no “load” on the two standard hardware-store batteries, they will last for years. A test button and LED allow for occasional verification of battery performance."
