Til dem der kan li oldschool formater og musik, så er der lavet en tracker (musikprogram) kaldet BeRo Tracker. Det gode ved den er at den kan afspille nogle af de gamle formater, og eksportere dem til wav, men med upsampling.
The features of BeRoTracker:
- It's modular!
- Loads MOD XM S3M IT MT2 IMF BRT 669 STM MTM WOW OKT
- Saves MOD XM S3M IT and my own format BRT
- VST/VSTi support
- BTP/BTPi support (my own VST/VSTi alternative)
- Automations (incl. VST/VSTi/BTP/BTPi parameter automations)
- Extended instruments (for example: you can assign a VSTi/BTPi directly to a instrument without the normal way over the MIDI instrument settings, but this does in my tracker too)
- Drum Patterns
- IIRLowPass / IIRHighPass / FIRLowPass / FIRHighPass / FIRBandPass / FIRNotch Filter
- Extra cutoff AND resonance instrument envelopes!
- LFO for each instrument envelope!
- Extended instrument envelopes
- supports 8/16/24/32 Bit & 32Bit FloatingPoint Mono/Samples Samples
- Raw / Linear / CubicSpline / WindowedFir / PolyphaseFir / Sinc8 / Sinc16 / Sinc32 / Sinc64 / Sinc128 / Sinc256 / Sinc512 / Sinc1024 Resampling
- a high quality 32-bit floating point mixer
- extended automatic click removal
- Extended pattern editor with more columns (extra Pan&Filter colums)
- Piano Roll Editor (only in BeRoTracker Classic)
- MIDI In
- Multi-MIDI Out
- Up to 255 base channels
- WAV export (up to 192 kHz, 8/16/24/32 bit/32bit floating point)
- MIDI export (incl. midi macros)
- can import & export most all modplug tracker extenstions correctly (sorry, ModPlug-junkies
- extended effects (for example: you can assign directly a effect number to a VST/VSTi/BTP/BTPi parameter)
- complete written/coded in object pascal (Delphi/FreePascal) include playerengine
- VSTi version of this tracker is also available
and more... (The real feature list will be too big for this list)
