Lidt mere om next gen. HD.
http://gizmodo.com/348985/next+gen-hdtv-is-so-clear-itll-make-you-throw-up-i-see-
no-problems-with-this
You may recall that last May I told you about Super Hi-Vision,
the next-generation in high def that promises an insane resolution of
7680x4320, or 16 times the resolution of HDTV. It turns out that it
much be a little too high-def; it's so realistic it might just make you sick.
Yes, fast moving images at that resolution will probably cause
motion sickness according to the eggheads at Japan's NHK who are
developing the technology. Adding to the practical issues the format
will face is that there's no real way to cram that many lines of
resolution into a display any smaller than 60 inches, and even if you
could cram them into a smaller screen there'd be no point to it. You
wouldn't be able to tell the difference anyways at that point.
Despite the fact that the format isn't expected to be broadcast
until 2025, NHK has built what's probably the sweetest home theatre
setup in the world to play around with it: a 500 inch Super Hi-Vision
screen hooked up to the world's only 22.2 multi-channel surround sound
system. Take that, Panasonic. [BBC
