Den har en forst. på 1200 Watt. Den er cool og alle ville nok kunne finde plads til den.
Drivers: active 6.5" forward firing anodized aluminium cone (5" piston
diameter) 2 x 6.5" side-firing passive radiators with aluminium cones
(5" piston diameter)
ERS class D amplifier: 1200 watts Dynamic power, 600 watts RMS
Frequency response: 38-120 Hz +/-3 dB
Digital Dynamic Driver Control: yes
Phase: 0 or 180 degrees (selectable)
Low-pass crossover: 50 Hz - 200 Hz (adjustable), 12 dB octave, 48 dB ultimate
Auto on/off: yes
Magnet structure: 1.8kg
Voice coil: 2" dual layer
Inputs: speaker-level, mini-jack and gold plated line-level
Outputs: speaker-level (120 Hz high-pass crossover), mini-jack (through)
Subwoofer direct (crossover bypass): yes
Cabinet (hwd) includes grill: 22.9 x 22.9 x 24.4 cm
Warranty: electronics - 3 years (parts/labour) / driver - 5 years (parts/labour)
Shipping weight (approx.): 9.1Kg
Finish: black or white
http://gizmodo.com/gadgets/small-package/microv
ee-sub+woofer-packs-1200+watt-punch-into-9+inch-cube-290515.php
