3D-displays & kildematriale
Teori & generelt om billede-teknologi.
Indlægaf zerocool » ons jun 20, 2007 02:13
Foranlediget af udviklingen i denne tråd, synes jeg det det ville være rart med en selvstændig tråd om udviklingen indenfor 3D.
Jeg kan fortælle at Philips netop har annonceret en ny 3D skærm. Se mere her: http://www.business-sites.philips.com/3dsolutions/about/article-15442.html
Og her er lid pdf-filer vedr. teknologien bag: http://www.business-sites.philips.com/3dsolutions/Downloads/Index.html
zerocool
Geografisk sted: Århus C
Indlægaf Raskolnikov » ons jun 20, 2007 10:04
Spændende-Lucas har lavet et selskab hvis eneste formål der at lave film fra 2D til 3D. Håber snart vi ser resultaterne af dette.
Indlægaf Raskolnikov » fre aug 24, 2007 10:28
Mitsubishi kommer med 3D BD afspiller...hmm. Color me skeptical, men det bliver da spændende at se hvad det er for noget.
http://gear.comon.dk/index.php/news/show/id=14150
og her er lidt mere om teknologien.
We've seen a couple attempts at large-scale 3D displays that split DLP's 120Hz display rate into two 60Hz HD fields, but Mitsubishi
is apparently showing off a slightly more advanced version of the
technology at The Barclay's PGA Tour event, featuring 3D content on Blu-ray
discs. According to CNET, the company showed off a Blu-ray system using
a "massive" Dell desktop and a large DLP display that enabled viewers
to watch commercials, movies, and sporting events in 3D using special
stereoscopic glasses. The content had been shot in 3D from the get-go,
but Mitsubishi says it's working on a Blu-ray player that will be able
to turn standard 2D content into simulated 3D -- and that it'll be out
early next year. The company also coyly hinted that it's talking to a
"console manufacturer" about integrating the tech into a game system.
We'll give you one guess as to who that might be.
http://www.engadget.com/2007/08/24/mitsubishi-working-on-3d-blu-ray-players-displays/
Indlægaf zerocool » fre aug 24, 2007 15:51
Raskolnikov skrev:Mitsubishi kommer med 3D BD afspiller...hmm. Color me skeptical, men det bliver da spændende at se hvad det er for noget.
Ja, det er da bestemt interessant, at endnu en af de større producenter kommer med et udspil i 3D-henseende. Real-time konverteringer af 2D-matriale anvender dog nogle ret tunge algoritmer og er yderst processorkrævende, så jeg tror vinderen i det lange løb bliver filmselskaberne, der uden tvivl vil lave remasterede genudgivelser af oprindlige 2D-film, hvor de har anvendt kvalitativt langt bedre off-line-processer til formålet.
3D-processorer, der opererer i real-time, er dog helt sikkert noget vi kommer til at se i vid udstrækning i stand-alone-apparater, afspillere og 3D-skærme, som et overgangsfænomen.
zerocool
Indlægaf CPH-R » fre aug 24, 2007 16:19
Raskolnikov skrev:Spændende-Lucas har lavet et selskab hvis eneste formål der at lave film fra 2D til 3D. Håber snart vi ser resultaterne af dette.
det kommer nok til at hedde "2D-to-3D-THX-Star-Wars-Once-Again-And-Mony-In-The-Bank-Again"
Jeg ved godt hvem der er Luke Skywalkers far "jeg fangede det i 2D versionen"
CPH-R
Geografisk sted: 3450
Indlægaf xo » fre aug 24, 2007 17:28
Det er en spændende fremtid vi går i møde. Den 3-d skærm jeg på ved sidste Cebit var skuffende, men det kan kun blive bedre.
CPH-R skrev:Jeg ved godt hvem der er Luke Skywalkers far "jeg fangede det i 2D versionen"
I find your lack of faith disturbing!
xo
Indlægaf zerocool » fre aug 24, 2007 21:16
xo skrev:Det er en spændende fremtid vi går i møde. Den 3-d skærm jeg på ved sidste Cebit var skuffende, men det kan kun blive bedre.
Sådan er det jo med al ny teknologi. Hvem husker ikke kvaliteten af de første fladskærme eller digitale projektorer. Ligeså kommer 3D-displays jo også til at gennemgå en modningsfase.
zerocool
Indlægaf Otto J » lør aug 25, 2007 12:54
Jeg vil i min sædvanlige konservatisme påstå at egentligt overbevisende 3D kun er muligt med computergrafik, og/eller mere eller mindre kunstige optagelser hvor der benyttes flere kameraer. Det er fysisk umuligt at optage 3D fra én kameravinkel. Alene dette vil i praksis begrænse udbredelsen af 3D. Derfor tror jeg at 3D aldrig rigtigt bliver ret meget mere end en gimmick ala IMAX. Under de rette omstændigheder og med de rette optagelser kan det givetvis levere nogle fantastiske oplevelser, men et egentligt alternativ som film-format bliver det efter min mening aldrig.
De 3D prototyper jeg har set til dato har været direkte ubrugelige mht. kvaliteten, men som nævnt vil teknologierne naturligvis forfines hen ad vejen. Personligt mener jeg ikke 3D er relevant, før det kan leveres med samme billedkvalitet som 2D. Dén oplevelse af realisme som 3D kan levere, går lidt fløjten hvis billedkvaliteten ikke er realistisk.
Mvh. Otto
Otto J
Indlægaf xo » lør aug 25, 2007 13:02
Det tror jeg ikke du har ret i, for CG er endnu ikke derhenne hvor det kan skabe helt fotorealistiske film. Men det jeg tror du har ret i, er at der skal mere end ét kamera til før det blir rigtigt godt. Men jeg skal ikke kunne sige hvor godt de nye 3D DSP processer fungerer, jeg har kun set en enkelt 3D skærm.
xo
Indlægaf Otto J » lør aug 25, 2007 13:05
xo skrev:Det tror jeg ikke du har ret i, for CG er endnu ikke derhenne hvor det kan skabe helt fotorealistiske film.
Til den tid hvor 3D displays matcher 2D displays på billedkvaliteten, er CGI formentligt nået en del videre end i dag. Og "høj billedkvalitet" behøver ikke betyde "fotorealistisk", det er to forskellige ting.
Mvh. Otto
Otto J
Indlægaf xo » lør aug 25, 2007 13:15
Det er muligt, men det er den overordnede parameter der betyder noget for mig.  :)
xo
Indlægaf Otto J » lør aug 25, 2007 14:46
xo skrev:Det er muligt, men det er den overordnede parameter der betyder noget for mig. :)
Vi er enige... :-)
Mvh. Otto
Otto J
Indlægaf Raskolnikov » fre aug 31, 2007 10:29
Et firma har opfundet 3D projection a la Star Wars  :D
http://www.engadget.com/2007/08/31/rese ... c-display/
Se en video her.
Indlægaf zerocool » søn sep 02, 2007 22:47
Raskolnikov skrev:Et firma har opfundet 3D projection a la Star Wars :D
http://www.engadget.com/2007/08/31/researchers-develop-a-360-degree-holographic-display/
Se en video her.
Så synes jeg den danske pendant er noget mere imponerende: http://www.hifi-musik.dk/?page=visnyhed&id=511
I øvrigt er her en spændende artikel vedrørende udviklingen af 3D.
zerocool
Indlægaf Otto J » søn sep 02, 2007 23:01
Jeg kan lige tilføje at uden at jeg havde tid til at nærstudere samtlige stande på IFA, så var de 3D displays jeg så dér nøjagtigt lige så ringe som de plejer at være. Jeg tror vi mht. 3D skal forlade os på helt nye teknologier, som f.eks. videreudviklinger af ovennævnte holographic-teknologi eller lignende. Jeg tror ikke rigtigt på at det nogensinde kan lade sig gøre at vise 3D realistisk på et display der i bund og grund ER 2D.
Mvh. Otto
Otto J
Tilbage til Display, Tv & signalkilde-teknik
