Kings nye riaa amp !
Indlægaf king » ons aug 22, 2007 06:34
Her laver de en Rega arm der kan køre balanceret med rca !
http://www.hi-fi.com/diy/rega/steps.html
Putting on the RCAs - Next figure out which is the left channel and which is the right by stripping the shielding back to expose the signal wire. This time strip the metal braid shielding as well. The red and green wires are the right channel, the white and blue the left. The red positive wire is soldered to the center pin of the right channel RCA (usually a red or gray plug) and the green negative to the outside ring. The white positive is soldered to the center pin of the left channel RCA (usually a white or black plug) and the blue negative to the outside ring. How this actually works depends on what brand you chose. I recommend you find one which is solderable. Also make sure the steel braid shield is tucked inside the rubber shield. Pulling on the rubber shield so it covers a closely trimmed metal shield will usually handle this. If you roll your own lead wire and do not have a rubber shield, make absolutely sure the metal shield, which is connected to ground, does not come in contact with anything that contact the positive and negative channel's signal wires. Use heat shrink back from the point were the wires separate left and right and stop the metal shielding there.
If you require balanced outputs, this is a simple step. Check the pin designations on the phono inputs. The pins are numbered and their designation should be listed in your owner's manual. In most cases, pin one is Ground, pin two is Positive and the third pin is Negative. For the ground, in this case, the metal shielding would be twisted, tinned and soldered to the third pin.
XLR-Cinch-Adapter für PHONO2CI
AQVOX - Cinch RCA jack /XLR-plug Adaptor for PHONO2CI - makes TRUE balanced CURRENT amplification easy possible.
! Important: only the balanced input has the unique-sonically advantages of a TRUE BALANCED - CURRENT AMPLIFICATION!
85% of all tested MC-cartridges do sound better at the balanced input, but there are some MC´s sounding better at the RCA voltage amplifier input.
Therefore it should always be tested, at which input a MC cartridge sounds better.(most MM-cartridges have to high impedance for the XLR-input)
For connecting tonearms (with MC-cartridges) with RCA-plugs (Cinch) at the XLR balanced input of the PHONO2CI phonoamp. Herewith a REAL balanced operation is possible. Only the balanced input is a current amplifier. This rarely found balanced-current-input is really a rare circuit. Most of all tested MC´s do sound better at the current input. Only in balanced mode the CURRENT-Amplifier input for MC´s is active! AQVOX strongly recommends to try also the RCA input, because somel tested MC-cartridges do sound better at the RCA input, which is a voltage-amplifier.
Also with balanced XLR input, the unbalanced RCA output is active!
High-quality strong IT-full-thermoplastic-XLR-plugs.
Gold plated precision machined bronce contacts.
Gold plated less metal RCA(Cinch)-jacks with OFC-Copper wire.
Soldered-connection made with highsilver-solder
Be carefully, that at the cartridge or the Phono2Ci or other equipment can be damaged if not used with care. You are using the adaptors at your own risk! If the adaptors or phonocables get in touch with the metal-case of the Phono2Ci or any other devices or ground or the turntable etc.. . Be aware, if using these adaptors the outer metalpart (screen) of the RCA adaptor which is normally ground/mass is now HOT. The screen has become a signal-carrier! So any contacts to earth/ground is a short-cut! So always unplug all your components before connecting disconnecting anything!
If you have questions regarding this, please consult your local dealer or contact us!
2. ATTENTION! most REGA-Tonearms may need for best balanced operation a simple modification, a separation of the tonearmground from the left channel signal-ground. (for instructions click here)
3. ATTENTION! Adaptors offered for example from Neutrik (NA2MPMF) and similar models are NOT compatible, because wired like IEC 268-12: Pin 2 = Signal; Pin 3und Pin1= Ground/screen
AQVOX XLR/RCA:
XLR-Pin 2 = Signal+ = connected to RCA center pin
XLR Pin 3 = Signal- = connected to RCA ground (collar)
XLR Pin 1 = screen is NOT connected to RCA
This adaptor is necessary for testing the full sonic performance! In case the MC-system sounds better at the XLR (balanced current amplifier) input, the optimum is to change the phonocable to a balanced one (either two hot wires in one screen, or two hot wires and no screen) . For this please consult your dealer or us.
No matter, if the balanced XLR input or the unbalanced RCA input is used. Both outputs are usable at the same time!
Hør musik - ikke optagelser !
king
Geografisk sted: Aabenraa
Indlægaf king » ons aug 22, 2007 07:05
Hva med denne her http://www.passlabs.com/preamps/xono.htm
Er den heller ikke balanseret på udgangen så... ?
king
Indlægaf Ro » ons aug 22, 2007 14:33
Hvad angår den Pass Labs vil jeg knytte samme kommentar som til din nye RIAA.
Hvis minus polerne er adskilt fra hinanden og adskilt fra Ground på RIAA og man lykkes med at lave en grounding af signalt fra pladespiller så er vilkårene udvendigt til stede.
Så er det spørgsmålet om produktet har 2x2 adskilte RIAA forstærkninger internt som svinger om ground som nulpunkt.
Ellers kan man betragte muligheden for output gennem XLR som en service til dem der har XLR indgange i deres forforstærker.
SÃ¥ synes jeg bare at firmaerne skal undlade at blande snak om balanceret drift ind i deres salgstaler.
Men måske er de reelt forberedt for blanceret drift.
Det kan kun nærmere undersøgelse af RIAA trinene afsløre.
Første undersøgelse vl være nem: Er minus på de to RCA stik elektrisk adskilt? Er Ground helt adskilt fra alle andre stikforbindeser?
Hvis du vælger at undersøge det, vil du så ikke være rar at "offentliggøre" resultatet her?
;-) / Ro
Ro
Tilmeldt: søn aug 05, 2007 22:26
Indlægaf Janils » ons aug 22, 2007 23:01
Her et eksempel på en ægte balanceret MC/RIAA (Allen Wright - Vacuum State Electronics) med FETs og rør. Jeg har hørt den på triodefestivalen for nogle år siden, og den spiller mildt sag rigtigt godt. Den er dog også dyr - selv hvis man bygger den selv. Alene strømforsyningen (som ikke er vist her) er et projekt for viderekomne.
Et større diagram og forklaringer kan findes her:
http://www.soton.ac.uk/~apm3/diyaudio/RTP3.html
... og her et diagram med IC'er samt transformerudgang:
Indlæg ændret af administrator. Billeder der indrykkes på forummet må maksimalt være 600 pixels brede.
Indlægaf king » fre aug 24, 2007 15:30
Ja... sådan ser mine stik ud hvis jeg køre Balanceret ind i riaa - læg mærke til selve stel ud fra rca stik og en stel mere fra arm !!
king
Indlægaf Ro » fre aug 24, 2007 15:46
Hej King.
Det kan godt være at det virker til balanceret drift!
Hvordan er de ground forbindelser forbundet i pladespillerenden af kablerne og er det ground fra RCA stikkene bare koblet til minus på h.h.v. højre og venstre kanal ellr er den adskilt fra minus?
Og stadig sniger spøgsmålet sig på om der er en adskillelse af minus polerne på RCA stikkene og ground på selve RIAA'en?
Og om der er 2x2 seperate forstærere internt i RIAA'en?
Måske ved dem der hat solgt dig grejet mere om det...............det er da værd at undersøge.
;-) / Ro
Ro
Indlægaf king » fre aug 24, 2007 15:52
Der går en adskilt stel i selve kablet og der er også en stel adskilt fra kablet !
Har snakket med dem - og selve kablet er lavet til Balanceret og selve riaa er 100% Balanceret !
Skulle hilse og sige hvis du er i tvilv skulle du kikke på deres hjemmeside og kikke (læse hvad de skriver om den) !!!!!!!!!!
Prøv at kikke pÃ¥ et VDH kabel - 2leder og skærm som du bruger til stel i venstre og det samme i høje kanal - samt en særskilt stel ved siden af kablet !
king
Indlægaf Ro » fre aug 24, 2007 18:38
Jeg synes bare at det er super godt at den virkelig er balanceret.
Så er det med at udnytte det fra "vugge til grav" (fra pick up til højttaler) og køre balanceret hele vejen igennem!
Du må ikke tro at jeg ønsker at kaste skår i glæden.
Jeg var alene drevet af min forundring og min nysgerrighed i dette spørgsmål og denne afklaring glæder mig på dine vegne.
Endnu engang tillykke med din nyerhervelse.
;-) / Ro
Ro
Indlægaf Dolce » lør aug 25, 2007 17:05
Det ER da godt din RIAA er balanceret, sÃ¥ ved vi det
Dolce
Tilmeldt: man apr 10, 2006 12:20
Indlægaf king » søn aug 26, 2007 10:42
Jeg fik hørt Densen Riaa i gÃ¥r til Expert demo - og den spiller sku musik
Den kan varmt anbefales - hvis du skal ud og høre pÃ¥ div riaa !
http://www.densen.dk/index.php?page=products&produkt=pho nostage
king
Indlægaf Skorpio » søn aug 26, 2007 11:46
Er den virkelig fuld balanceret internt så er det jo synd de har sparet XLR stikkene væk....så hellere spare phono og lave et adaptor kabel hvis man vil køre single-ended....
Skorpio
Indlægaf king » søn aug 26, 2007 12:38
Skorpio skrev:Er den virkelig fuld balanceret internt så er det jo synd de har sparet XLR stikkene væk....så hellere spare phono og lave et adaptor kabel hvis man vil køre single-ended....
Det er jo ikke alle arme der kan køre balanceret - så heller lave en riaa som kan køre bægge dele !
http://www.aqvox.de/tonarm_en-balanced.htm
king
Indlægaf 3DX » søn aug 26, 2007 17:51
king skrev:Ja... sådan ser mine stik ud hvis jeg køre Balanceret ind i riaa - læg mærke til selve stel ud fra rca stik og en stel mere fra arm !!
er de to stel spader forbundet ?
jeg mangler altså en stel...
er det ikke en der kan lave en skitse ? er der ikke "kun" 2 x 2 stik på PU, samt arm stel ?
Indlægaf king » man aug 27, 2007 06:36
Dolce skrev:Det ER da godt din RIAA er balanceret, sÃ¥ ved vi det
Ja.... det er jo ikke en Thorhauge riaa som din
king
