Endnu to HD formater
Teori & generelt om billede-teknologi.
Indlægaf Raskolnikov » man sep 10, 2007 15:09
Så er der endnu en spiller i kampen om den næste HD stadard for faste medier.
As if two different high definition DVD standards weren't enough for the world, China has gone ahead and said "actually, it is, at least for the western portion of it." The Optical Memory National Engineering Research Center has announced CH-DVD, a high definition DVD standard based on the DVD Forum's HD DVD, but with additional Chinese-owned technology tacked on. This additional technology takes the form of advanced copy protection designed to prevent the spread of pirated content. A new foundation called the China High Definition DVD Industry Association will be promoting the format, with the aim of launching a hardware player in 2008, and getting content producers on board before that.
bliver spændende at se hvor meget dette kommer til at betyde.
Senest rettet af Raskolnikov tirs sep 11, 2007 11:57, rettet i alt 1 gang.
Indlægaf Raskolnikov » tirs sep 11, 2007 11:55
Update med ENDNU et HD format!!  :roll:  :shock:
Og et andet amerikansk format:
http://www.thedigitalbits.com/#mytwocents
Finally, in the "You've Got to Be F-ing Kidding Me!" category, it seems that there's a THIRD high-def disc format on the way. According to this story at Yahoo, a company called New Medium Enterprises is soon to launch HD VMD (Versatile Multilayer Disc) at Amazon and Radio Shack stores. HD VMD discs hold 30GB of data and feature a data rate of 40 mbps using MPEG-2 and VC-1 (AVC may be added later). The main selling point is that the cost to consumers is much lower than either Blu-ray or HD-DVD. Their player will sell for just $150. If I had to guess, I'd guess this will be a non factor. What studio is going to want to sell their movies on a THIRD HD format? It sure doesn't make decisions any easier for consumers. Ugh.
Stay tuned...´
http://news.yahoo.com/s/pcworld/2007090 ... rld/136977
Indlægaf Tag » tirs sep 11, 2007 15:21
CH-DVD og HD VMD ud over Blu-Ray og HD-DVD, må da værre dødstødte for alle HD disk formater, og så er der kun en vinder nemlig DVD.
Der skal nok komme flere HD diske formater, hen af vejen.
Tag
Indlægaf xo » tirs sep 11, 2007 18:06
Hvorfor ikke, kan man spørge. Blu-Ray og HD DVD sammenslutningerne kunne ikke enes, nu kan det være de kommer fra asken til ilden af samme Ã¥rsag. Men jeg tror nu ikke Kinas format vinder indpas udover i asien og det nye amerikanske format har vel heller ikke de store chancer. Men til prisen er det da apellerende.
xo
Re: Endnu to HD formater
Indlægaf zerocool » ons sep 12, 2007 00:26
Raskolnikov skrev:Så er der endnu en spiller i kampen om den næste HD stadard for faste medier.
og
Raskolnikov skrev:Update med ENDNU et HD format!! Rolling Eyes Shocked
Som jeg læser det, er der alene tale om 2 nye optiske lagringsmedier til data, herunder video. De pÃ¥tænkte encodningstyper til levende billeder er de samme som ved Blu-Ray og HD-DVD og man kan derfor ikke tale om egentlige nye HD-formater som sÃ¥dan.
zerocool
Geografisk sted: Ã…rhus C
Indlægaf Raskolnikov » ons sep 12, 2007 09:15
Ja du har ret i at der endnu ikke er nogle film ppå nogle af formater. Men det ser da ud til at i hvert fald HD VCD får film til billige priser i fremtiden....hvilke selskaber og film dette bliver er så noget andet.... :wink:
Tilbage til Display, Tv & signalkilde-teknik
