Radiohead tråden
Radiohead tråden
Indlægaf Raskolnikov » søn jun 03, 2007 15:49
Update med info om udgivelsen .  Se seneste indlæg-
Jeg glæder mig så meget til det næste Radiohead album og faldt over dette i dag.
Billede filnavn: 2kf6d922b1e5.jpg
Maybe you were like us and wondered what that strange mannequin head
was doing staring at Thom playing the piano in the April 22 update over
at Dead Air Space. Jason M. wrote in to explain what this is and we thought we would pass it on to you.
Have you seen the mannequin head that Radiohead has in the studio?
It's specifically in the DEAD AIR SPACE photo from Sun, Apr
22nd titled "Over your shoulder..."It's actually a rarely used form of recording technology called "Binaural Recording".
Microphones are built into a fake head made of material that mimics how soundwaves pass through the human body.
The two main openings, the ear canals, create an exact replication of how humans hear the sounds in real life.
Basically, on the new album, you'll be hearing some of the tracks,
mainly piano, as if Thom was playing it in the same room as you.
Here's the wikipedia article for more information.
http://www.greenplastic.com/
Kan huske at der er eksempler på teknikken på Monster Inc. dvden.
Dette lyder meget spændende!
Senest rettet af Raskolnikov fre okt 10, 2008 11:52, rettet i alt 4 gange.
Indlægaf burning777 » tors jun 07, 2007 20:03
WOW - spændende læsning. Bliver spændende at lytte til det album med hovedtelefoner. Må være som at sidde der selv.
Er den teknik brugt i andet musik - ville gerne finde Jazz som er optaget på den måde.
Nogen der kender noget?
Venlig hilsen
Rasmus Horn
burning777
Tilmeldt: ons maj 09, 2007 15:34
Geografisk sted: Sunds
Indlægaf zerocool » tors jun 07, 2007 20:37
burning777 skrev:Bliver spændende at lytte til det album med hovedtelefoner. Må være som at sidde der selv.
Teknologien er faktisk udviklet specifikt med henblik på hovedtelefon-brug og der er sågar producenter, der laver hovedtelefoner specielt hertil. Ex.: http://www.etymotic.com/ephp/er4.aspx
F.sva. almindelige hovedtelefoner er der også forskel på, hvor godt de dur til formålet. Fra Wikipedia:
"However, these in-ear-canal phones tend to suffer from poor externalization i.e. inside-head localization. It is also found that even normal headphones suffer from poor externalization, especially if the headphone completely blocks the ear from outside. A better design for externalization found in experiments is the open-ear one, where the drivers are sitting in front of the pinneae with the ear canal connected to the air. The hypothesis is that when the ear canal is completely blocked, the radiation impedance seen from the eardrum to the outside has been altered, which negatively affects externalization.
There are some complications with the playback of binaural recordings through normal headphones. The sound that is picked up by a microphone placed in or at the entrance of the ear channel has a frequency spectrum that is very different from the one that would be picked up by a free-standing microphone. The diffuse-field head-transfer function, that is, the frequency response at the ear drum averaged for sounds coming from all possible directions, is quite grotesque, with peaks and dips of 10 dB. Frequencies around 5 kHz in particular are strongly attenuated as compared to side-presentation. If headphones were designed to have a flat response, then they would sound much too 'bright' when used to listen to stereo recordings and for this reason, most headphones are designed to have a notch around 5kHz. This can only ever approximate to a particular listener's ears, meaning that there can be no such thing as a 'flat' pair of headphones - they have to match the listener's ears, unlike speakers which aim to produce a flat free field response. For binaural listening though, the headphones need to have a flat response to the ear-canal entrance (not the eardrum) since it is at the ear-canal entrance that the recording microphones are placed. While it is in theory possible to equalise any headphones for a flat response at the entrance, a better approach is to use headphones designed without the notch in the first place.
The fact that most headphones are actually designed to have a notch in the 5kHz region is not widely understood, and this may have led to errors in the assessment of binaural recordings, since flat headphones are not normally available, and 'high quality' headphones incorporate the notch just like any others, though perhaps with a better approximation to that needed by the average ear. Male and female ears are of course different in size, and the outer ear gets bigger with increasing age, raising the possibility that most headphones are only really suited to young men. If headphones were designed to be flat, with a choice of equalisations available in headphone amplifiers, then headphone listening could be a more controlled experience, whether in binaural or stereo mode."
Hvis man skal opnÃ¥ noget af effekten pÃ¥ et almindeligt anlæg, vil det forudsætte convolution med FIR-filtre, der korrigerer for egenakustikken ens eget lytterum og der vil da stadig være noget at hente med hovedtelefoner, da optagelsesmetoden ikke tager højde for afstanden mellem højttalere og lytterens ører.
burning777 skrev:Er den teknik brugt i andet musik - ville gerne finde Jazz som er optaget på den måde.
  • Zuccarelli Holophonics (The Matchbox Shaker) 1983 demonstration recording[citation needed]
  • The Final Cut 1982 album by Pink Floyd[citation needed]
  • Dreams Less Sweet 1983 album by Psychic TV[citation needed]
  • The Pros and Cons of Hitchhiking 1984 album by Roger Waters[citation needed]
  • The Cabinet of Dr. Fritz 1984-85 radio drama produced by the ZBS Foundation
  • Finn 1995 album by the Finn Brothers (back of CD booklet includes a picture of the brothers with a dummy head)[citation needed]
  • Flow Motion 1976 album by Can
  • Fra Wikipedia.org
    zerocool
    Geografisk sted: Ã…rhus C
    Indlægaf burning777 » tors jun 07, 2007 21:12
    Ud fra årstallene på den musik du nævner ser det ud til at det er en teknik man har brugt en gang i 70-80-erne - og nu Radiohead igen. Er det fordi det ikke er helt så godt som man skulle tro eller måske bare et "modefænomen" dengang?
    Eller er det bare fordi man ikke går så højt op i at optagelserne skal lyde godt nu om dage?
    Venlig hilsen
    Rasmus Horn
    burning777
    Indlægaf Raskolnikov » tors jun 07, 2007 21:30
    Jeg tror det er lidt af begge dele. Dels et modefænomen og så det faktum at alting bliver produceret med MP3 som mål idag
    Jeg låner lige dette fra et andet forum:
    "Kunsthoved-stereofoni er en ret interessant teknologi, som kan give en god rum-definition (det er især kunsthovedets øreflip, som gør forskellen i forhold til alm. mikrofonteknologi). Men det er en gammel teknologi!
    Danmarks Radios P2 sendte i 80'erne på forsøgsbasis koncerter optaget med denne teknologi. De sendte bl.a. live en Bruckner-symfoni indspillet med et kunsthovede hængende ned over 6 række i radohusets koncertsal!
    De lavede også en del radioudsendelser, som forklarede teknologien, og de lavede i den forbindelse en del sjove indslag. Jeg har fx en optagelse, hvor radiokoret står i en cirkel rundt om kunsthovedet og på skift tæller - altså "1", "2", "3", osv. Det lød ret effektivt under live-transmissionen, når man lyttede med hovedtelefoner. Man kunne fornemme koret stå rundt om én, og man kunne klart udpege de enkelte medlemmer!"
    "martin-faroe"
    Der er også et eksempel her:
    http://www.i-am-bored.com/bored_link.cfm?link_id=22913
    ( husk hørebøffer)
    SÃ¥dan poster man billeder:
    Indlægaf zerocool » tors jun 07, 2007 21:41
    burning777 skrev:Ud fra årstallene på den musik du nævner ser det ud til at det er en teknik man har brugt en gang i 70-80-erne - og nu Radiohead igen. Er det fordi det ikke er helt så godt som man skulle tro eller måske bare et "modefænomen" dengang?
    Kvaliteten, eller mangel pÃ¥ samme, ved nyere optagelser er diskuteret mange gange her pÃ¥ forummet. Diskussionerne har i reglen taget afsæt i dynamisk komprimering og studiernes stadig stigende niveau-ræs, men det er helt sikkert, at moderne optagelser ogsÃ¥ lider under andre mangler.
    Af nyere optagelser med binaural teknik kan nævnes enkelte numre på Perl Jam's album "Binaural" fra 2000.
    Her finder du dog adskillige lydklip, optaget med binaural teknik: http://freesound.iua.upf.edu/tagsViewSingle.php?id=1190
    Er du interesseret i, at lave normalt-optaget musik mere hovedtelefonsvenlig kan dette gøres med stereophonic-to-binaural DSP (bs2b), der simulerer binaural optagelse. Se http://bs2b.sourceforge.net/ og http://sourceforge.net/projects/bs2b.
    zerocool
    Indlægaf burning777 » fre jun 08, 2007 07:54
    Raskolnikov skrev:Der er også et eksempel her:
    ( husk hørebøffer)
    Fantastisk - jeg tror jeg skal til at lede efter musik optaget på den måde rundt omkring.
    Venlig hilsen
    Rasmus Horn
    burning777
    Indlægaf burning777 » fre jun 08, 2007 08:03
    zerocool skrev:Af nyere optagelser med binaural teknik kan nævnes enkelte numre på Perl Jam's album "Binaural" fra 2000.
    Tusind tak for det! Har forsøgt at installere det program. Men det er vist ikke lige designet til Mac. Ser dog meget spændende ud. Vil lege lidt med det på Winslows-platformen.
    Har dog fundet et par andre programmer, der også skaber lydbillede og med specielle opsætninger til hovedtelefoner dog nok ikke helt efter samme princip:
    http://www.srslabs.com/consumerhome500.asp
    Er gratis og kører fint med iTunes.
    Venlig hilsen
    Rasmus Horn
    burning777
    Indlægaf burning777 » fre jun 08, 2007 08:05
    zerocool skrev:
    TAKKER for tippet - "The final cut" er nu på vej til mig fra Amazon :-)
    Venlig hilsen
    Rasmus Horn
    burning777
    Indlægaf Raskolnikov » man okt 01, 2007 12:58
    Og det udkommer snart! Faktisk næste uge!! WOW :shock:
    Og man får det både på vinyl og CD. COOL!!!!!!!!
    Billede filnavn: 2k80c20c4687.png
    Radiohead announce new album, you pick the price
    September 30, 2007 07:21 PM - Posted by Jonathan
    Well, well, well. Radiohead, err Jonny more like it, announced that a new Radiohead album will be released on October 10th. Yes, you read it correctly. October 10th. That is next week.
    Billede filnavn: 2kfbf8cb8cf6.jpg
    It will be called In Rainbows and the way it will be released is quite interesting. First off, it will only be available on www.inrainbows.com initially. Secondly, it appears that they are releasing this album without a signed deal with a record company. Of course, many of us have been saying for years that they don't need EMI or any label.
    If you go to the site now, you'll notice that there are two options for pre-ordering: Discbox and Download.
    What is the difference?
    DISCBOX
    THIS CONSISTS OF THE NEW ALBUM, IN RAINBOWS, ON CD AND ON 2 X 12 INCH HEAVYWEIGHT VINYL RECORDS. A SECOND, ENHANCED CD CONTAINS MORE NEW SONGS, ALONG WITH DIGITAL PHOTOGRAPHS AND ARTWORK. THE DISCBOX ALSO INCLUDES ARTWORK AND LYRIC BOOKLETS. ALL ARE ENCASED IN A HARDBACK BOOK AND SLIPCASE.
    THE ALBUM DOWNLOAD AUTOMATICALLY COMES WITH THIS PACK. YOU CAN DOWNLOAD THE FILE DIGITALLY FROM THE 10TH OCTOBER 2007.
    DISCBOXES ARE BEING MADE TO ORDER AND ARE PRICED AT £40.00 INCLUDING POSTAGE. SHIPPING WILL BEGIN ON OR BEFORE 3RD DECEMBER 2007.
    Tracklisting:
    CD 1 AND VINYL
    15 STEP
    BODYSNATCHERS
    NUDE
    WEIRD FISHES/ARPEGGI
    ALL I NEED
    FAUST ARP
    RECKONER
    HOUSE OF CARDS
    JIGSAW FALLING INTO PLACE
    VIDEOTAPE
    CD 2 AND VINYL
    MK 1
    DOWN IS THE NEW UP
    GO SLOWLY
    MK 2
    LAST FLOWERS
    UP ON THE LADDER
    BANGERS AND MASH
    4 MINUTE WARNING
    DOWNLOAD
    If you don't want to pay for all the extra stuff, you can simply download the songs on October 10th. How much does it cost? YOU DECIDE. Radiohead is letting you choose how much to pay. No really, it's up to you.
    Tracklisting:
    15 STEP
    BODYSNATCHERS
    NUDE
    ALL I NEED
    FAUST ARP
    RECKONER
    HOUSE OF CARDS
    VIDEOTAPE
    Indlægaf Raskolnikov » man okt 01, 2007 16:03
    Denne skal helt sikkert hjem. Så har man ikke engang dilemmaet om det skal være cd eller lp :D
    Indlægaf E45 » man okt 01, 2007 19:59
    Det er genialt - og alle pengene går tlRadiohead, ikke et slipse-pladeselskab, very nice!
    E45
    Indlægaf shkristensen » man okt 01, 2007 20:29
    Angående det der download: Er der nogen der ved om det er almindelige kedelige mp3'ere man skal afgøre hvad man vil betale for, eller er det rigtig CD-kvali?
    Jeg syntes det har lidt at sige når man skal afgøre hvad man vil betale. Udover dette syntes jeg det er et godt initiativ, som man skal støtte, at der ikke skal spildes penge på grådige pladeselskaber.
    shkristensen
    Tilmeldt: man okt 01, 2007 20:24
    Geografisk sted: Odense
    Indlægaf Raskolnikov » man okt 01, 2007 20:52
    Jeg tror ikke der ligger info om hvad kvalitet det er i endnu, men jeg kan garanterer at det er non-DRM :P
    Indlægaf xo » tirs okt 02, 2007 21:04
    Bestem selv prisen, det er da et fedt koncept, hehe.
    http://newz.dk/radioheads-7-album-bestem-selv-prisen
    xo
