tosa skrev:Er der egentligt nogle lydkort der har HDMI ud (som kan levere de 24-bit/96kHz ud)??
tosa skrev:OK, ærgeligt. Men tak for info
Jeg fik vist talt lidt for hurtig vedr. om det var en god idé. Ifølge denne artikel har mange recievere tilsyneladende svært ved at håndtere et lydsignal via HDMI, når det ikke er ledsaget af video: http://www.electronichouse.com/article/pc_audio_cards_vs_hdmi/D1/
As for HDMI audio-only, oye! Many surround processors and receivers do not support audio-only HDMI, even when video switching is available. Also, in the opinion of some high quality gear makers, like Arcam, HDMI audio-only suffers in performance. Confusion about this HDMI audio-only issue abounds. For example, one forum post I found, supposedly from HDMI.org, stated that the HDMI signal always requires a video signal (it requires the video clock signal) in order to send audio (which sits in the blanking period of the video signal). However, even a blank/dummy pattern (such as all black) video signal would work, so the audio does not have to be linked with a specific HD video signal.
Det er dog ikke noget, som jeg har haft mulighed for at hverken af- eller bekræfte, ligesom jeg ikke ved om forholdet gør sig gældende f.sva. din Onkyo-reciever.
