Vinyl guf!
Indlægaf Raskolnikov » tirs jan 08, 2008 19:07
He he. Ja det er ret vanvittigt!  :lol:
SÃ¥dan poster man billeder:
Indlægaf Raskolnikov » lør jan 12, 2008 13:20
Det her må da siges at være en solid plov!!
Hele pladespilleren er bygget sammen med bordet. Og det ser ud som om det er bygget i granit.
Fundet her:
http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=54678&whichpage=19
Indlægaf krenzler » lør jan 12, 2008 16:03
Tonearmen er den meget besynderlige "Thales".
http://www.6moons.com/industryfeatures/ ... hales.html
krenzler
Geografisk sted: KBH Ø
Indlægaf Raskolnikov » søn jan 13, 2008 17:59
Flere Plove på CES:
Alt sammen via Stereophile.
I was rocking out in the DeVore Fidelity/Tone Imports room, listening
to Polly Jean Harvey. In the midst of the hurly-burly of CES, I was
feeling no pain. "I love the way you guys decided to set your Silver
Diamondback References up assymetrically," I told JDV.
"It's the only way we could get the separation we needed," said
John DeVore. "Those things," he pointed at Tone Imports' EMT TSD
cartridge ($2200), the Tone EMT 997 "Banana" tonearm ($4495) and the
monophonic Sentech EQ10 phono curve equalizers ($3000/each), "throw
such a huge soundstage, we just couldn't do it with the Silverbacks
closer together.
The EMT 997 now comes with SME or Ortofon A mounts.
Old-school analog lovers have long been hipped to the pleasures of "long-throw" tonearms—the EMT 997 made a believer out of me.
Ny tonearm fra Kuzma
Det er dælme en støvet plade!
France Kuzma was showing a fascinating tonearm, the $7300–7500 4Point,
named because it has unique vertical and horizontal bearings. Kuzma
said, "It's like a unipivot tonearm that can't 'chatter' in the
horizontal plane."
But well designed unipivots aren't supposed to chatter.
"No, they are not supposed to."
A rigid VTA tower allows repeatable VTA and azimuth adjustments.
The tonearm fits on 9" configurations, said Kuzma, but "is effectively
11"."
"And it is biwired," said Kuzma.
It has eight special silver-alloy wires coming out of the
cartridge. Four of them are continuous to the phono preamp, where they
are terminated with Eichmann Bullet connectors, but the other four
terminate in a breakout box with Cardas female RCAs, so you can use two
different phono sections."
Here's the kicker: I was hipped to the Kuzma tonearm by digital
designer Kevin Halverson. "It's the slickest piece of mechanical
engineering, I've seen in a long time," Halverson said.
Og den famøse McIntosh plov.
I got another chance to see—and this time, hear— the $9000 MT10 turntable. "You know, this product generated more comments in our CEDIA2007 blog than any other component."
"Yeah," said the McIntosh rep. "Mostly about how ugly it looks. I think
it looks a lot better in person." Me, too—plus, they were playing a
huge stack of new Warner Music Group LPs. What's cooler than new vinyl?
Big Mac is touting the MT10 as plug-'n'-play: Tracking force,
antiskating, and cartridge "position" are preset at the factory. The
tonearm has two horizontal sapphire bearings and two vertical ceramic
bearings for "the possible friction." The ebony-bodied cartridge has an
elliptical stylus and puts out 0.5mV.
"Did the speed meter say 78RPM in Denver?"
"Yep."
"I missed that detail."
"Yes, you did."
They say the real test of someone's beauty is if spending time
with them is worth your while. The MT10 is growing on me—checking it
out just might be time well spent.
Indlægaf Kristian » lør jan 19, 2008 13:01
Kristian skrev:Mon ikke den her vil stå i min stue en dag...
Havde for mange år siden en orginal Xerxes med Artemis arm og Artaxerxes riaa. Den orginal Xerxes var meget dårligt bygget men den kunne lyde meget meget imponerende når den var rigtig justeret. Savner dens hurtig og klarhed gang imellem. Sådan TMS2 sammen med en Naim Aro kunne være et klasse setup, særlig med klassiken.
Den nye Xerxes ser også flot ud.
Nåå...
er nogen her der har erfaret sig med den nye Xerxes 20 og artemis 2 ?
Indlægaf Raskolnikov » lør jan 26, 2008 12:02
MÃ¥ske lidt off topic, men synes alligevel det er vinyl guf
So
you really like turntables, do you? Perhaps you're a self-styled DJ, or
maybe you're just one of those awkward vinyl aficionados who tut-tuts
every time someone talks about MP3s. In any case, I'm sure you're
looking to rub what you consider to be such a sweet hobby/obsession in
the faces of others. This turntable watch is modeled after the classic
Technics 1200 down to the tiniest detail, so much so that you'd swear
you could spin some wax on it if only records came in such wee sizes.
It's available now for $65 and a small shred of your dignity. [Product Page via Book of Joe
http://gizmodo.com/348943/turntable-watch-ok-ok-we-get-it-you-like-vinyl
Indlægaf Raskolnikov » søn jan 27, 2008 13:11
Jeg faldt lige over denne Riaa, som har fået meget gode omataleser. Nogle der kender den?
Pure Sound P10 Riaa med rør. Kun til MM.
http://puresound.info/id1.html
"The P10 phono amplifier is the latest addition to the highly acclaimed
                           Pure Sound product range.
It is intended to meet the requirements of audio enthusiasts who still enjoy the distinctive
                           strengths and high quality of reproduction that can be derived from vinyl records.  It
                           is compatible with moving magnet and high output moving coil cartridges.  Low
output moving coil cartridges will require the use of an additional
step-up device or matching transformer.  Full output from the P10 is sufficient to drive the line level inputs of any integrated amplifier or pre-amplifier"
Indlægaf Raskolnikov » tors feb 28, 2008 11:44
Indlægaf Raskolnikov » ons mar 12, 2008 17:30
Dette er virkeligt et tilfælde hvor teknikken er vigtigere end musiken!!
Det gad jeg dælme ikke, lige meget hvor god lyd der kommer ud...
http://www.youtube.com/watch?v=VZM8iNTZruY&feature=related
Sådan en Michel Gyro måtte derimod godt snore hjemme hos mig
Det er sgu smukt!
http://www.youtube.com/watch?v=jj80jep42oI&feature=related
Indlægaf Kristian » ons mar 12, 2008 17:59
Raskolnikov skrev:Dette er virkeligt et tilfælde hvor teknikken er vigtigere end musiken!!
Det er sgu smukt!
Den her ser også meget spændende ud
http://www.youtube.com/watch?v=21IGt1YSHrA&feature=related
Indlægaf Raskolnikov » tirs mar 18, 2008 14:53
Synes dette ser spændende ud.
Tweaks til Regaer.
http://www.audioenz.co.nz/2007/vinyl_superrega.shtml
Groovetracer-subplatter
Groovetracer aluminum subplatter
Har altid syntes at plastikken på Regas subplatters gav et lidt billigt indtryk...nogle der har prøvet det på deres rega?
Der er også denne arkryl tallerken.
http://www.audio-ideas.com/reviews/analog-sources/rega-tweaks-4.html
Billede filnavn: 2k7713f340cc.jpg
Indlægaf Raskolnikov » tors mar 20, 2008 00:26
SÃ¥ sidder man her og surfer lidt og sÃ¥ bliver man fristet af en Clearaudio Nano Riaa ogsÃ¥ lige nÃ¥r man ikke har rÃ¥d!  :o
Aktiv hifi har den billigt Pt. De har også en Smart Phono billig...åhh nej! He he.
http://www.activhifi.dk/tilbud1.html
Den har jo fået god omtale i tyskland....
http://www.clearaudio.de/index1.html
MUST RESIST!!  :lol:
Indlægaf HenrikW » fre mar 21, 2008 02:33
Hej gutter,
mange spændende pladespillere i denne tråd må man sige :) Jeg har brug for lidt guidance, er der nogen af jer der har kendskab til den efter hånden halvgamle Ortofon AS 212 arm? Jeg har netop erhvervet mig et Thorens TD321 værk monteret med en sådan arm.
Armen har desværre set bedre dage, tror den er hevet af en konstruktion der havde løfter knap monteret i plinten, så der er iukke længere nogen hæve/sænke funktion - så længe man har fingre så går det nok. Bort set fra dette samt lidt kosmetiske skavanker ved montering så er den "ok".
Men, er det noget der dur eller er jeg bedre tjent f.eks. med en Rega arm ala RB250 eller 300 eller måske noget helt andet? Selv går jeg og drømmer lidt om en mørch up4 arm eller måske en af SME IV arm men begge er godt over mit budget.
I får lige et billede af armen her:
Mvh. Henrik
HenrikW
SonusFabolous
Indlægaf HenrikW » søn mar 23, 2008 16:13
Slet ikke nogen der kan huske denne tonearm :?:  :)
HenrikW
SonusFabolous
Indlægaf king » søn mar 23, 2008 16:51
HenrikW skrev:Slet ikke nogen der kan huske denne tonearm :?: :)
Nej.....
Hør musik - ikke optagelser !
king
Geografisk sted: Aabenraa
