Toshiba:SD upconvert er lige med HD
Herunder DVD- & HDD-Recordere.
Indlægaf Raskolnikov » tirs jun 17, 2008 23:17
Toshiba arbejder efter HD DVD nedlaget på en ny teknologi der skulle give lige så godt billede som HD. ( ifølge dem )
Denne revolutionerende teknologi er....upkonvertering af DVD til HD.
For the attentive in attendance, you likely noticed that none of
Toshiba's newly announced laptops (yes, even the absurdly powerful Qosmio rigs) have built-in Blu-ray drives. Like, there's not even an option.
When questioned about the obvious oversight (ahem), Tosh's Europe CEO
Alan Thompson noted that "Blu-ray was just one of the many ways that
you can get HD content and is not required for accessing HD content."
Furthermore, it seems as if the outfit is continuing on in its pursuit
to develop the best DVD upconverting technology in the whole wide world,
as it explained to the press in London that its forthcoming technology
would "fill in the gaps" and "add resolution." Company representatives
even remarked that "Blu-ray was only a storage medium," and reiterated
that BD "wasn't the only way to view high-def content." It's one thing
to bow out gracefully, pick up the pieces and get on with life. It's
another thing to douse yourself in ignorance and pretend that Blu-ray
(let alone HD DVD) never happened.
Read - Toshiba's London press event
Read - Toshiba Europe CEO comments
Fra her
SÃ¥dan poster man billeder:
Indlægaf Spencer » ons jun 18, 2008 07:56
Og MPEG artefacts og Edge Enhancement er ikke længere noget problem?
Kommer de også med en ny superkraftig duftfrisker, der kan få gyllelugten fra en nygødet mark til at forsvinde?
Det er stadig dårlig MPEG-2 der ligger på en DVD, så de må have røget et eller andet tobak, der ikke er lovligt i USA.
Mange DVD-udgivelser er endda bevidst sløret i billedet, for at modvirke line flicker.
Dét at et punkt ikke ved om det tilhører den ene eller anden scanlinie, og derfor hopper frem og tilbage med flimrende billede som resultat.
Hvilke DVD-udgivelser mener de er gode nok til at konkurrere med blu-ray?
Nej - det Toshiba siger, er at forbrugeren ikke kan se forskel - og dermed undergraver de deres eget HD-DVD koncept også.
Toshiba er godt i færd med at ødelægge deres egen troværdighed.
Her er et eksempel på MPEG artefacts.
Den skade kan deres opskalering næppe rette op på.
En helt anden ting, er at der er detaljer i HD-billedet, der slet ikke er til stede på DVD'en.
Denne demo giver et godt billede af hvor meget man mister på en DVD, sammenlignet med HD.
Detaljer i tøjet og håret, er helt fraværende på DVD'en.
Spencer
Tilbage til DVD, HD-DVD & Blu-Ray-afspillere
