Skærme med Wireless HD på vej
Kabler, scalere, set-top-bokse, satellit m.m.
Indlægaf Raskolnikov » tors aug 21, 2008 08:28
     Det bliver rigtig spændende at følge hvornår vi får trådløs HD billede / lyd i vores hjem og i hvilken kvalitet det bliver. Men det giver helt klart nogle muligheder for at indrette ens hjem anderledes og f.eks. slipper man for en streambox under tv'et hvis det har indbygget Wireless HD.
Be happy: A new wireless HD video standard guarantees that major brands
including Sony, Sharp, Hitachi, Samsung and Motorola will have
interoperable wireless video streaming. Amimon—the chip makers behind
the "video modem" wireless HD tech we've been seeing on and off for the last few years, and most recently in Belkin's Flywire—is announcing the WHDI consortium with the above members, formed to standardize their wireless HD spec and embed it in member companies' TVs, projectors and HD video sources. The result is a network of HD components, streaming uncompressed 1080p video not just through one room like competing UWB standards, but to and from any source to any TV
in your entire home, with a range comparable to Wi-Fi. Pretty impressive stuff.
The change in range is due to the chunk of spectrum being used (5GHz for WHDI and anywhere from 3.1 to 10.6 GHz for UWB). UWB is a low-power, short-range broadcast because it has to play nice with the other protocols found on the wide breadth of spectrum it calls home. (For better or worse, Monster's wireless HD kit is wireless up until the point it needs to use your home's coax wiring to gain whole-house coverage). WHDI, however, is camped out in a chunk of unlicensed 5GHz spectrum
just like 802.11n Wi-Fi, meaning it must be able to tolerate the reasonable levels of interference only from other devices that use the same frequencies, and can broadcast at higher power levels than UWB—enough for a range of "over 100 feet." WirelessHD, a third major spec also funded by Samsung and Sony, plus Panasonic, Toshiba, LG and NEC, uses the 60GHz band, and apparently has problems unless the transmitter and receiver are within line-of-sight.
Components will be paired through menu systems using a pass-key, like Bluetooth. The spectrum can hold around six streams of 1080p video at a time, although real-world interference may vary. A likely scenario would be streaming from a WHDI cable box or Blu-ray player downstairs to 3 TVs throughout your house while still having room for HD gaming in the den.
The fact that a few heavies like Panasonic are still notably missing
could mean another standards battle is on the horizon. While WirelessHD
already claims a published 1.0 spec, and Monster's UWB product should be out by the fall, the WHDI spec is due to be finalized at the end of the year, with products hopefully popping up in time for CES '09. Stay tuned until then—as one format war ends, another begins.
Og det første tv er på vej
While there have been several other ultra-thin TVs to cheat on size by moving
some of the set's guts into an external box, we're starting to see a
few of the biggies taking advantage of the newly-codified WHDI spec to beam the signal from the external box to the screen wirelessly. Details are somewhat thin
on these new concept Mitsubushi panels, which are 40mm (a hair over 1.5
inches) thick and should reach manufacturing before the year is up. But
their use of WHDI (like these Sharp sets before them) to link the panel to the external tuner box adds an interesting twist to this trend.
Trading a few millimeters shaved off the panel for a big honking box may not seem like a hugely advantageous situation, but WHDI has a range of over 100 feet (into the closet it can go) and allows for seamless pairing of compatible HDTV gear throughout your home, meaning the tuner (or the external Mitsubishi Blu-ray recorder shown next to it) could potentially be linked to other panels in the house. I kind of like the idea of stashing all of my modular source gear in a home theater server room of sorts, leaving only ultra-thin panels to receive the signals visible. That seems to be where WHDI is taking us, although Panasonic (who is not a WHDI member) could have something else up their sleeves. [Tech ON]
Indlægaf CPH-R » fre aug 22, 2008 10:21
Vi har haft nogle i butikkerne i snart ½ mdr....
Virker helt perfekt.
http://www.loewe.dk/
Peter
CPH-R
Geografisk sted: 3450
Indlægaf Raskolnikov » fre aug 22, 2008 10:28
Men det er så vidt jeg kan ikke et HD 1080p signal eller et Dolby True signal?
Indlægaf CPH-R » fre aug 22, 2008 11:21
Nej ikke som det leveres i dag ”nu har jeg ikke personligt haft med Loewe at gøre mere end et lille års tid” men er blevet helt solgt til deres tv…! Hvis man går ind i fabriks menu`, er der bunker af indstillinger parate til fremtiden eks. Et hav af mpeg4 formater ect. ect.
Man kan jo afspille musik direkte fra en usb nøgle, men ændre man en bit setting, kan man afspille mpeg4 film direkte fra dens usb indgang ”har ikke afprøvet om den vil tage film direkte fra en hd” men kan ikke se hvorfor den ikke skulle kunne det.
Men jeg tror Loewe har besluttet ikke at tilbyde for mange optioner lige nu, da træerne ikke vokser ind i himlen..!? folk har svært nok ved bare at tilslutte en NAS som det er i dag… hvilket resulterer i at forhandlerne har kunderne i telefonen konstant.
En sidste ting man skal bruge en del tid på..!? at konverterer filerne til et format som man kan streame, det er mange forskellige mpeg4 formater, hvis man ikke blot vælger divx, bare den tid for en 720p er ca. et lille døgn pr. film, desuden skal man joine eks VBO filer først.
Men ingen tvivl om at de har flere ting i baghånden…!
PS: tænk at jeg skulle blive imponeret over hvad et TV kan… :oops:
Peter
CPH-R
Indlægaf Raskolnikov » fre aug 29, 2008 19:03
Sony nyeste LCD skulle også blive trådløs. Trådløs betyder åbenbart 1080i og ingen 24fps. HUH?
We're got a tipster telling us that Sony's new 9.9-mm thin, wireless Bravia ZX1 is absolutely, without a doubt, based on Amimon's WHDI (pre-standard) wireless technology. Not surprising given Sony's and Amimon's collaborative effort to make WHDI a proper standard. Still, when we asked Sony, they gave us a sly grin followed by a, "no comment." Sony was willing to confirm a "guaranteed" 1080i transmission at a range of up to 20-meters. Amimon, on the other hand, can transmit 1080p / 30fps at distances up to 30-meters, you know, just as long as you're not separating devices with a wall of Kevlar and Kryptonite. Sony also told us that we can expect the thinster to land in Euroland before Xmas, but not the US where it would seem they have a different, non-integrated wireless model prepping for release. We'll see at CES in January if not earlier.
herfra
Indlægaf Raskolnikov » tors sep 04, 2008 08:49
Sony kommer med den første skærm med WHDI i år-Vi ser det nok først i EU næste år...
Just like we spied earlier today, Sony's two baddest IFA LCD TVs—the 9.9mm-thin KLV-40ZX1M LCD (above) and the 200Hz Motionflow Z4500
(below, known as the KDL-52XBR7 at 240Hz here in the U.S., due to our
30fps broadcasts vs. Europe's 25fps)—are both getting an official U.S.
rollout here at CEDIA. Jesus got a chance to fondle 'em in Berlin last
week where U.S. details were slim, but both sets will be shipping
stateside in December. Both have whole-house WHDI wireless HD streaming
built-in from Amimon. No official pricing on either, but they'll be
top-end, for sure (rumored to be $4,500 for the ZX1). Full release
follows:
The BRAVIA KDL-52XBR7 LCD TV features 240Hz high frame rate technology, delivering exceptional motion detail in movies, sports and video games. Meanwhile, the BRAVIA KDL-52XBR7 LCD monitor features a revolutionary slim design measuring just 9.9mm, or about the thickness of a Compact Disc jewel case.
“Sony continually pushes performance and design innovation beyond any other television manufacturer,” said Jeff Goldstein, vice president of marketing for Sony Electronics’ Home Product Division. “From the top to the bottom of our TV line, Sony offers unmatched performance and design.”
The full HD 1080p 52-inch diagonal KDL-52XBR7 incorporates Sony’s new Motionflow™ 240Hz technology delivering an exceptionally crisp and detailed image with natural motion.
The Motionflow algorithm goes beyond traditional 120Hz technology by quadrupling the frame rate of conventional LCD TVs and interpolating three new frames, producing remarkably crisp and natural motion.
Other picture enhancements include Sony’s Advanced Contrast Enhancer (ACE), which helps deliver a dynamic contrast ratio of 80,000:1 and BRAVIA Engine™ 2, Sony’s digital video processor that enhances all incoming signals to match the TV’s 1080p resolution.
The model also is compatible with Sony’s BRAVIA Link modules providing the ability to seamlessly add new features. Optional expansion modules include the BRAVIA DVD Link, the BRAVIA Wireless link, the BRAVIA Input Link, which will ship later this year, and the currently available BRAVIA Internet Video Link.
The BRAVIA Internet Video Link module attaches to the back of a
selection of Sony’s 2007 and 2008 BRAVIA LCD flat-panel television
models. The service seamlessly streams on-demand entertainment
including movies, TV programs, your favorite YouTube videos and a
variety of other content not found on network or cable/satellite TV.
The service connects to the Internet via your existing broadband
Ethernet connection and streams content, much of which is avaialble at no additional charge Content is easily navigated with Sony’s Technical 2007 Emmy® award-winning Xross Media Bar (XMB)™ user interface.
Rounding out the feature set is Digital Media Port (DMP) compatibility, which provides access to video and music from portable media devices like compatible Walkman® and iPod® players and other DMP accessories, which are sold separately. The models also can display digital photos and play digital music using a creative multi-plane 3D graphics slideshows from USB devices, as well as access photos from your PC in another room using Digital Living Network Alliance® (DLNA)® compliant devices via your home network.
Sony’s new 3D Favorites Menu complements the XMB graphical user
interface, which has also been enhanced with Sony-unique integration of TV Guide providing easy access and navigation of content and menus through colorful thumbnails and logically placed icons.
Inputs found on the KDL-52XBR7 include four 1080/60 24p HDMI™
connections (HDCP), two 1080/60p HD component inputs, a
1080/60p-capable PC input, and an Ethernet (RJ-45) port.
Sony is also introducing the 40-inch diagonal 1920 x 1080p KLV-40ZX1M flat panel LCD monitor. The revolutionary super-slim display measures just approximately 9.9mm deep – about the depth of a Blu-ray Disc jewelcase – and weighs about 26 pounds.
The model features an edge-lit wide color gamut LED backlight
delivering exceptional color reproduction and detailed contrast and
Sony’s Motionflow 120 Hz technology for exceptional clarity and
resolution when viewing film or video content with motion.
Other features include Sony’s BRAVIA Engine 2, a single HDMI input and compatibility with Sony’s BRAVIA Wireless Link allowing users to stream high-definition content wirelessly to the monitor from high-definition sources such as a set-top cable or satellite tuner or Blu-ray Disc™ player.
Other optional accessories include a flat-matching speaker bar with
four full-range speakers and two tweeters and a wall-hugging bracket
that completes the stunning package.
Both the BRAVIA KDL-52XBR7 and KLV-40ZX1M will ship this December. They will be offered at sonystyle.com and at Sony Style retail stores nationwide, as well as at authorized Sony dealers across the country.
herfra
Bliver spændende at se om denne trådløse teknologi kan hamle op med alm. HDMI.
Indlægaf Raskolnikov » lør sep 06, 2008 07:53
Den første box til wireless HDMI skulld komme i år.
Og en mere er på vej
Tilbage til Tilbehør
