Da Hansen V2 The prince blev testet i Stereophile udtalte Lars Hansen at han startede med at udvikle højtalerenhederne. Dette gjaldt dog ikke diskanten, da han havde fundet en diskant der var så god at den ikke kunne forbedres. Er der nogen der ved hvilken diskant enhed han bruger.
"I start with the drivers," said Lars Hansen. "First, I found a tweeter so good that even I couldn't improve upon it. The motor assembly has so much control over the soft dome that it reproduces the silences between notes every bit as well as the notes themselves" TWEETER -Engineered, designed and manufactured for Hansen Audio -25mm high performance dome mounted on a dispersion optimized 6mm aluminum plate -Precision assembled |
