HD Guru afprøver Burn-In myten
Teori & generelt om billede-teknologi.
Indlægaf Raskolnikov » ons dec 02, 2009 20:24
Siden HD Guru har afprøvet og undersøgt Burn In problemet på plasmaskærme. Konklusionen er at det faktisk ikke er noget problem man bør tænke på længere...
http://hdguru.com/plasma-tv-burn-in-fact-or-myth/826/
"Burn-in, a "faint outline of a previously viewed image caused by uneven
phosphor wear," turned out to be far more difficult to cause. Gary
couldn't do it by freezing a frame for ten hours, nor by seeking out
showroom demo plasma HDTVs that might have been on a burn-causing loop.
In the end he concluded that the effect might be created in a
"worst case scenario" which involves "100% viewing of 4:3 content with
black side bars [instead of gray], or exclusive viewing of 2.35:1
aspect ratio movies (without using one of the zoom modes to eliminate
the black bars) and leaving it on that way continuously for weeks."
SÃ¥dan poster man billeder:
Indlægaf Bulgarien » fre dec 04, 2009 18:52
Glimrende, sÃ¥ sker der trods alt forbedringer . MÃ¥ske skulle man købe sig en flad  - om ti Ã¥r.
(siger en lykkelig ejer af et B&O Avant billederør fjernsyn ;-)  )
Bulgarien
Tilbage til Display, Tv & signalkilde-teknik
