Wikipedia skrev:
Morello is famed for his guitar style, which consists of heavy metal/punk hybrid riffs and hip hop-inspiredsounds. His guitar playing is also characterized by heavy use of guitar effects, such as delay, modulation, wah, harmonizers, distortion, feedback, and others in unique ways and combinations. The most recognizable effect in Morello's arsenal is the Digitech Whammy, which helps him create many of his sounds. Matthew Bellamy of the English band Muse has cited Morello as an influence, which can be heard in his use of pitch-shifting in solos.To produce his alien guitar sounds, Morello chooses various effects pedals. During his tenure in RATM, he used a Dunlop Cry Baby, a Digitech WH-1 Whammy, a Boss DD-2 Digital Delay, a DOD EQ pedal (set flat and just used to boost the
In the studio, Morello uses the same setup for the bulk of the guitar tracks. For The Battle of Los Angeles, he also used a few other amps, such as a Line 6 as heard on the clean, spacey intro of "Mic Check", plus a Pignose mini-amp and a MusicMan "Twin" style amp. During the recording of Audioslave's last album Revelations
volume during guitar solos or particular rocking moments), and an
Ibanez DFL Flanger. Around the time of The Battle of Los Angeles
he added a Boss TR-2 Tremolo pedal (which can be heard on "Guerrilla
Radio"). For Audioslave, Morello replaced the Ibanez Flanger with a MXR Phase 90. His amplifier of choice has always been a 50-watt Marshall JCM 800 2205 and a Peavey 4x12 cabinet. Though the Marshall is his amp of choice with Rage
Against the Machine, he used a Vox AC30 combo amplifier for multiple
overdubs on Audioslave's 'Revelations' album. While the Marshall
amplifier has two channels, he only uses the overdrive channel, and
simply turns down the volume on his guitar to get cleaner sounds.
Morello experimented with different amplifier setups. For the title
track's solo he split his signal to his standard Marshall 2205 head and
Peavey cabinet and a 100 watt Fender Bassman head and an Orange cabinet.
With delay sent to one while the other is unaffected the sound is being
"ping-ponged" between the two amplifiers. He also borrowed a VOX AC30 amplifier from producer Brendan O’Brien for some tracks.
