Pro Logic 11x or Nero:6
Indlægaf Strutton » tors jan 26, 2006 16:05
Hi,
Please excuse me using English.
I have a Pioneer Receiver VSX-D814 that allows me to use my 7:1 speaker setup, using Pro Logic 11x or Nero:6.
Are there any advantages or disadvantages when choosing either system?
Regards
Roger
Venlig hilsen
Roger
Strutton
Tilmeldt: søn okt 23, 2005 19:19
Geografisk sted: Assens
Re: Pro Logic 11x or Nero:6
Indlægaf zerocool » tors jan 26, 2006 23:39
Strutton skrev:
Hi,
Regards
Roger
Pro Logic IIx and Neo:6 are both systems that extract the different surround channels from a stereo signal, unlike Dolby Digital or DTS where you have the channels on separate tracks. Pro Logic is developed by Dolby Laboratories and Neo:6 by DTS.
They both work in somewhat the same way but are not “real” surround systems, in the true meaning of the word.
If I should choose, which I wouldn’t because I rarely use these formats, go for Pro Logic IIx. That is in my experience the best one of the two. If one of the true surround formats (i.e. Dolby Digital, DTS or one of their variants) is available you should however always choose one of these.
Pro Logic IIx
Neo:6
zerocool
Geografisk sted: Århus C
Pro-Logic or Neo:6
Indlægaf Strutton » fre jan 27, 2006 09:23
Thanks for the explaination.
I do use  the automatic button when playing DTS or Digital.
I do use the 5:1 when playing DVD-Audio and SACDs.
But I enjoy the 7:1 sound when playing normal CDs, and sometimes DVD-Audio and SACD, although I know they should default to 5:1.
Should the Automatic find out for itself whether the recording is mixed for 5:1 or 7:1?
Thanks for the clear explaination
Regards
Roger
Venlig hilsen
Roger
Strutton
Tilbage til Surround Sound
