Silver perle af et indlæg. Øh nej nok mere et guld-indl ægKritiske Lyttere skrev:Fremragende, så mangler vi bare at gøre noget ved de sidste ~50.000.000 centimeter frem til el-værket
Åh ja, folkene bag positive-feedback.com har en vidunderlig fantasi
Andre perler fra samlingen, en test af en magisk tusch fra Peter Belt (well, i virkeligheden er den vist fra Staedtler...):
As I said, I cannot discuss the scientific theory behind the pen, but here is a quote from the literature provided with it: "The P.W.B. ‘X’ Coordinate Pen has been induced with complex messages and when a human writes a message with the pen, the conditions on the object change in a similar way to the events in the ‘double slit’ experiment, in which the essential ingredient is the pure energy form of the photons and electrons which readily interact with the human observer."
...men nyd det hele her:
http://www.positive-feedback.com/Issue1/beltpen.htm
Forgyldte retningsbestemte (vekselstrøm?!) sikringer når ikke hr. Belts højder, men jeg må indrømme at jeg alligevel er en kende skeptisk. Nuvel, lad os endelig høre om erfaringerne.
Venligst
/kl
Kritiske Lyttere skrev:Tusind tak for velkomsten
Ja absolut, sætter skam stor pris på god musik, på ordentligt grej. Har været ramt af bacillen siden teenageårene, og det er efterhånden længe siden... suk...
Beklager, jeg prøver på at tøjle det, men jeg har lidt elektroingeniør i blodet og kan nogen gange ikke holde det tilbage
/kl
[...] the simplest way to prove the efficacy of the pen is to sign your name on the outside cover of a compact disc. You use your normal signature, and write it like this: Carol Clark > o.k. You need to include the "o.k." to transfer beneficial thought patterns from yourself to the written message.
When I listened to both copies of the CD again, the results were so startling that I wrote detailed notes. Vocals on the unsigned copy were hard and plastic sounding, and the high notes were razor sharp. I found myself totally distracted, wishing for the song to end. The treated CD, on the other hand, provided beautiful, mellow-sounding vocals. The high notes throughout were subdued, which enabled me to concentrate on the music. I found the experience enjoyable.
Absolut venligst
- kl
Karsten Sømand skrev:Sidder og grubler over, om ikke 3DX var med til omtalte lyttesession med Jan Nielsen (high-lighted)? Det kunne være spændende at høre lidt mere uddybende om oplevelsen.Næææh.. 3DX var ikke med, men det var jeg. Det foregik hjemme i min stue og vi var ganske rigtigt mere end almindeligt overraskede dengang.Den rent tekniske forklaring er nu ikke nødvendigvis så fjern, og allerede samme aften fandt vi en naturlig forklaring på fænomenet. Det handler efter min overbevisning om at hindre støj-overførsel fra et apparat til et andet og ikke så meget om støj fra lysnettet, endsige de klassiske floskler: "ren strøm, 50km kabel fra kraftværket, sølv/guld/whatever" og alle de andre mere eller mindre mærkværdige argumenter for og imod som vi har hørt igennem tiden.Desværre sidder jeg med en skadet højrehånd og kan kun skrive med venstre, så indlægget bliver ikke så langt.HilsenJohnny JensenJJAZ
De grinte godt nok og mente det var en joke. Men hvem grinte sidst? De var alle 3 hifi-folk og kunne lytte. Derfor var der heller ingen tvivl - der VAR forskel (især på DAC'en), men vi kunne hurtigt blive enige om, at priserne var vanvittige. Hvorfor der var forskel på kablerne tror jeg de diskuterer endnu
