Bliver man så snydt ved at købe TAD? Næææ, det synes jeg da ikke, for man får jo både højttalere, status symboler og branding af sig selv ved at købe dem...
ZIG skrev:@Morten BBliver man så snydt ved at købe TAD? Næææ, det synes jeg da ikke, for man får jo både højttalere, status symboler og branding af sig selv ved at købe dem...
Ah yes. The heart of hifi!
grausam skrev:ZIG skrev:@Morten BBliver man så snydt ved at købe TAD? Næææ, det synes jeg da ikke, for man får jo både højttalere, status symboler og branding af sig selv ved at købe dem...
Spot on ZIG
Du godeste det er det dummeste, jeg har hørt om HI-FI nogensinde .
We spent a great deal of time learning how Rega’s famous tonearms are made. One of the key steps involves fitting precision-made ball bearings to a stainless steel axle shaft, and then pre-tensioning those bearings for a minimum of play. Interestingly, bearing assemblies for Rega’s RB303, RB808, and RB1010 arms are all built in the same assembly are and use parts that, on paper, have all passed the same demanding QC tests. The difference, which is virtually impossible to measure but is easy to discern by feel, is that certain bearing sets have fractionally tighter tolerances than others, even though all of them have passed the same incoming inspection tests. Thus, when a worker encounters a set of these best-of-the-best bearings, they are set aside and reserved for use in Rega’s top-tier arms. To give you some idea of the ultra-tight tolerances we are talking about, note that standard RB303 bearings have about 4 microns of clearance before pre-tensioning and just 1 micron of clearance after pre-tensioning. By using the personal touch, the bearing sets used in the RB808 and RB1010-series arms are claimed to be able to achieve remarkable sub-1-micron tolerances after pre-tensioning.
MichaelSJ skrev:For nu at vende tilbage til trådholders udgangsspørgsmål:
Hvis den eksakte videnskab skulle have frit spillerum, skulle vi nok over i noget med, at vi troppede op og bankede på hos en anerkendt konstruktør, inviterede ham indenfor i stuen, hvor højttaleren skulle stå, og så bad ham om at konstruere det, der passer bedst til rummet og resten af anlægget uden skelen til prisen.
Hvad er det, der er så mega dumt? Det jeg sagde? Eller at Zig er enig med mig?
