mit hi-fi/stereo anlæg er sku heller ikke verden beste, men jeg nyder sku det jeg høre
nhj4 skrev:Der er intet hi-fi der er perfekt i min verden ej heller ikke Audio Note.
boydk skrev:Her et bevis på, at du Mickey i hvert fald ikke er helt alene![]()
Citat fra HumbleMadeHifi´s Capacitor shootout: Kan ikke få billedet med...
Vishay MKP1837 / 0,01uF MKP 100VDC - 1% tolerance
Technical specifications(according to manufacturer): "Metallised polypropylene, radial capacitor, designed for LC/RC filter circuits, coupling and de-coupling at high frequencies."
Sound: Many years ago I was tipped by Klaus Witte of Germany to try this capacitor as a small parallel cap for the Mundorf MCap Supreme. I tried them as a parallel cap for the tweeter series caps in my Progress speaker and I must say I was very impressed! To get straight to the point they don't change a Supreme into a Supreme Silver-Oil but they really do clear things up. I must admit I was sceptical at first as the value is only 10nF (0,01uF) - and the caps I was using at the time totalled to 12,6uF. The difference is most noticeable with classical music but also good quality recordings of jazz and fusion benefit: No change in sound stage width or depth but there is more concert-hall acoustics that let you get into the recording more. Not as liquid as a Mundorf Silver Oil but they did take away the slightly grainy edge from the Mundorf Supreme's. A noticable gain in clarity and transparency making instruments better separable from each other, the violins in an orchestra become a group of individual violins instead of one mass. Jazz drum brushes sound more like a brush than a "shush.
Læs evt. mere på
http://www.humblehomemadehifi.com/Cap.html
boydk skrev:Tror, du misforstod mit "skriv" og mit link.
Jeg skrev, at MickeyBG ikke var "helt alene i verden", hverken mere eller mindre![]()
Hvis du tolker det som en billigelse herfra, må det stå for din egen regning.
Jandk skrev:boydk skrev:Tror, du misforstod mit "skriv" og mit link.
Det opfattes ret nemt som en billigelse fra din side når du poster et link til noget der støtter tåbelighederne.
Mickey BG skrev:nhj4 skrev:Der er intet hi-fi der er perfekt i min verden ej heller ikke Audio Note.
Hvad er det for en diskant du har i?
kennethjensen skrev:Øhhhh Jan. Audio Note kan i den grad spille musik med smæk på. Og tilmed BRAGENDE højt uden at miste hverken overblik eller sammenhæng.
Spiller selv på komplet Audio Note system. Og jeg høre rigtig meget særdeles krævende musik. Og jeg savner absolut INTET. Trods de beskedne størrelse højtalere, så har jeg bedre bund, dynamisk kontrast og finesse i forhold til alt hvad jeg tidligere har haft. Så som bla Marten design Birds 2 diamond. Veriry Audio sarastro II EXT. Tad reference 1. Proac D80 som alle er fysisk meget større end mine Audio Note AN E ALNICO SIGNATURE.
Både min 211 trin og 300b pset trækker fint magnepan. Uden sved på panden. Men de kommer stadig ikke i nærheden af mine nuværende AN E, som både skaller bedre. Har bedre tone og kontrast.
Med hensyn til afkobling af delfiltret. Så det meget populært, ikke kun hos audioconsult. Men generelt. Trods det teoretisk ikke giver nogen mening. Så ændre det klangen. Kunne dog ikke selv finde på det i mine da jeg godt tilfreds. Så ser ingen grund til at pille.
Jeg har dog eksperimenteret en hel del med bypass over udgangs kondensatorer og afkoblinger i aktive kredsløb. Og det gør et eller andet. Ikke altid til det bedre.
Husk på at den teoretiske verden kun er belyst med meget få procent. Der findes uanet ting vi ikke kan måle eller helt forstå.
Prøv evt at måle rippel på frekvens gangen med og uden bypass caps. Også zoom in. Kræver et potent og analogt scope. Du ville blive lettere overrasket.
Pratisk teori er sjovt.
