af HES » fre aug 11, 2006 23:22
hvad med Monacor's ditto?
http://www.monacor.dk
søg på højttalerenheder og subwoofer-moduler
der er 2 SAM-1 til 2k og SAM-2 til 2,4k
SAM-1
Varenummer: 320640
With this subwoofer active module newly developed and manufactured in Germany, excellent subwoofer speaker systems for HiFi and home cinema can be built up in connection with the dual voice coil bass speakers (1 x 4Ω or 1 x 8Ω)) shown as follows as well as with all other high-quality bass speakers.
Subwoofer active module, 120W
Powerful active module of highest operating safety, due to jumpers suitable for subwoofers (12dB slope) and full range speaker systems, stepless phase control, ground lift switch of the professional technique against hum interference, 24dB subsonic filter, automatic switch-on system and extensive protective circuits (short circuit, overheating, and DC voltage overload).
In case of usual modern music material, with a crossover frequency below 100Hz, the power of the SAM-1 for the bass range corresponds to a total amplifier power for the full frequency range of several hundred watts.
Technical datasheet | Output power rms 4Ω | 90WRMS | Output power rms 8Ω | 65WRMS | Music output power 4Ω | 120WMAX | Music output power 8Ω | 90WMAX | THD at rms power | < 0.1% | Frequency range, full range | 20Hz-20,000Hz | Frequency range, satellite | - | Frequency range, subwoofer | 20Hz - (var. 50-150Hz) | Output impedance | 4-8Ω | Input impedance | line: 24kΩ/high: 17kΩ | Max. input voltage | | Line in | 4.7V mono/ 2.3V stereo | High power in | 33V stereo | Max. power of high level input 4Ω | 2 x 270WMAX | Max. power of high-level input 8Ω | 2 x 135WMAX | S/N ratio | > 70dB | Power consumption, no load | 2.5VA | Power consumption, stand-by | 0.6VA | Stand-by activation time | approx. 7 min. | Power supply | 230V~/50Hz/120VA | Required mounting cutout | 140x250mm | Mounting depth w/o front panel | 90mm | Dimensions | 170x280x95mm | Weight | 3.3kg |
Vejl. udsalgspris (inkl. moms) : 1.999,00 |
Forhandlerstempel
SAM-2
Varenummer: 320670
The new high-power subwoofer module SAM-2 with the perfect equipment and workmanship for active subwoofer systems of the highest quality. The filters operate perfectly, for the subwoofer as well as the high-pass filter, and a combination of systems of the highest quality is possible without any difficulties.
Subwoofer active module, 250W
High-power active module with extensive equipment: 24dB subsonic filter, var. low-pass filter: 50-150Hz (18dB), semiparametric bass boost (var. 30-50Hz midrange with boost up to 6dB, continuously adjustable), continuously adjustable phase control 0-180° for uncompromising room adjustment and set-up adjustment, var. high-pass filter: 50-150Hz (12dB) for equalizing the bass frequencies of the satellite amplifier and the satellite speaker, ground lift switch of the studio technology against hum interference, and various protective circuits (short circuit, overheating, and DC voltage overload). The great power can also perfectly drive enormous bass speakers with a diameter of up to 46cm, the sound and the workmanship are absolutely convincing.
The high-quality active high-pass Line Out of the SAM-2 with versatile adjustments can conveniently be used as a bass relief of the main speakers and for optimizing the sound. However, a regulated preamplifier output (Pre Out) is required for this. This kind of output is partly present at high-quality separable full amplifiers (Pre Out/Main In) or automatically provided by preamplifier/power amplifier combination or when using mixers.
Technical datasheet | Output power rms 4Ω | 200WRMS | Output power rms 8Ω | 125WRMS | Music output power 4Ω | 250WMAX | Music output power 8Ω | 180WMAX | THD at rms power | < 0.1% | Frequency range, full range | - | Frequency range, satellite | (var. 50-150Hz) - 20,000Hz | Frequency range, subwoofer | 20Hz - (var. 50-150Hz) | Output impedance | 4-8Ω | Input impedance | line: 20kΩ/high: 17kΩ | Max. input voltage | | Line in | 8.4V mono/4.2V stereo | High power in | 44V stereo | Max. power of high level input 4Ω | 2 x 480WMAX | Max. power of high-level input 8Ω | 2 x 240WMAX | S/N ratio | > 70dB | Power consumption, no load | 19VA | Power consumption, stand-by | 6VA | Stand-by activation time | approx. 7 minutes | Power supply | 230V~/50Hz/300VA | Required mounting cutout | 155x340mm | Mounting depth w/o front panel | 85mm | Dimensions | 185x370x90mm | Weight | 4.9kg |
Vejl. udsalgspris (inkl. moms) : 2.399,00 |
Gert (Gli-)
http://www.highend-sound.comAcoustic Solid, Amazon, Cardas cables, Herron Audio, Icon Audio, LAMM, Origin Live, Playback Designs, ProAc Speakers, PSB speaker, Rossner & sohn, Theil & Eton HT enheder, Trichord, Tri-planar, Tsakiridis Device, Unison, VDH, Wire World cables, 1000'vis vinyl ting + LP'er, pu-vægt
