Loudness in a turntable
Indlægaf Hiendenthusiast » ons jan 03, 2007 10:13
Can anyone tell me what determines the loudness on a turntable, have an old Philips with a cheap pick up , sounds very loud and clear , have another turntable Micro Zeiki , very beautiful with super S ortofon sounds very low, does anyone knows why?????
Hiendenthusiast
Tilmeldt: fre dec 22, 2006 08:42
Indlægaf HES » tors jan 04, 2007 00:10
Probably because the cheap cartridge is a MM (Moving magnet) type and the Ortofon is a MC (Moving coil) type. The MC cartridge needs a higher amplification, while the output is in the range of 0.5 mV, the MM has typical 2.5-5 mV output. You need a phono stage with possibility to connect MC cartridge.
Gert (Gli-)
http://www.highend-sound.com
HES
Indlægaf Hiendenthusiast » tors jan 04, 2007 13:37
Although i already wrote to thank you for the answer, now that i red it again  i am puzzled , the turntable that i am talking about about has MC Cartridge connected to so in essense i find your advice a little confusing , someone suggested i should add a pre-phono amp to it , what do you mean exactly by "phono Stage"? thanks for your patience, cheers JUlian
Hiendenthusiast
Indlægaf HES » tors jan 04, 2007 22:28
I mean
Your phono stage is only for MM cartridge, and the Ortofon is a MC, which needs a higher amplification than the MM does.
So to runn the Ortofon properly you need a phono stage which also can take the MC type, OR a step-up transformer between your existing phono stage and the Ortofon.
Sorry if I was a little unclear.
Gert (Gli-)
HES
Thanks again
Indlægaf Hiendenthusiast » fre jan 05, 2007 08:52
Lets forget about the old turntable Philips with MM cartridge.
All i want to know is about my Micro seiki MB18 wich has an Ortofon pick up  OM PRO S, that the sound level is low, from what i understand i have to buy a step up transformer , is that the actual name ?, or can it also be a power booster to connect between the turntalble and the Amplifier?
Thanks Julian
Hiendenthusiast
Indlægaf Boye » fre jan 05, 2007 10:02
The Ortofon OM PRO is an MM type, so I wonder if your amplifier has the right input with the necessary phono stage or RIAA amplifier. This input is typically named "Phono" or "Turntable". Compared to the other inputs, called line inputs (often named "CD", "Tape", "Tuner", "Aux" ...), this input has a higher gain as well as a frequency correction that boosts the lower frequencies to compensate for the way records are produced. (To put it simply).
Boye
Indlægaf HES » fre jan 05, 2007 19:54
My mistake thought you ment the super S was a MC, Boye is right the OM is a MM, so it should go in any phono connection. But it can be lower in output than your old Philips, tune up your volumen
Output voltage at 1000 Hz,
5cm/sec.
5 mV
Ortofon data: http://www.ortofon.com/html/profile.asp
Gert (Gli-)
HES
