af HES » tors jan 04, 2007 22:28
I mean
Your phono stage is only for MM cartridge, and the Ortofon is a MC, which needs a higher amplification than the MM does.
So to runn the Ortofon properly you need a phono stage which also can take the MC type, OR a step-up transformer between your existing phono stage and the Ortofon.
Sorry if I was a little unclear.
Gert (Gli-)
http://www.highend-sound.comAcoustic Solid, Amazon, Cardas cables, Herron Audio, Icon Audio, LAMM, Origin Live, Playback Designs, ProAc Speakers, PSB speaker, Rossner & sohn, Theil & Eton HT enheder, Trichord, Tri-planar, Tsakiridis Device, Unison, VDH, Wire World cables, 1000'vis vinyl ting + LP'er, pu-vægt
