Hjælp til meget irriterende streg i word!!
Alt ikke hifi-relateret.
Indlægaf Raskolnikov » tirs maj 08, 2007 12:06
Prøvede at oversætte dette til dansk...men det lykkes ikke.
Det er en irriterende streg der er til sidst i mit dokument og jeg kan ikke bare slette den! Hvad sker der?   Devil
"There is a line in my document that I can't delete because I can't select it. How did it get there, and what can I do about it?
Although there are other possibilities, most likely what you're dealing
with is the paragraph border that Word creates when you type three or
more hyphens (-), underscore characters (_), equals signs (=),asterisks
(*), tildes (~), or hash signs (#), and press Enter. Unless you have
cleared the “Borders” check box on the AutoFormat As You Type tab of
Tools | AutoCorrect, these characters are converted to a thin, thick,
double, broken, zigzag, or thick-and-thin border at the bottom of a
paragraph.
To make matters more confusing, this border is applied to the paragraph
before the one where you typed the hyphens, underscores, or equals
signs.
To remove this “line,” select the paragraph above it and, in Format |
Borders and Shading, choose None; or click the down arrow beside the
Borders button on the toolbar and choose the last (No Border) option in
the palette. Alternatively, you can simply click in the offending
paragraph and press Ctrl+Q, which resets the paragraph formatting to
the default for the style.
Note: If you've pressed Enter several times trying to get rid of
the line, you will merely have applied the border formatting to all the
paragraphs you added, as well as to the original one. This won't be
obvious, because when several consecutive paragraphs have the same
“border below” formatting applied to them, the border only appears
below the last of them. So If you then remove the Border formatting
from the paragraph that has the line below it, the line will move up
one paragraph. The trick is to select all the affected paragraphs and
either press Ctrl+Q or choose No Border.
It is a good idea to turn off most of the options on the
“AutoFormat” and “AutoFormat As You Type” tabs of Tools | AutoCorrect.
For more details, see Word is always making changes I don't expect. How
can I get more control over my formatting?"
Fra http://word.mvps.org/FAQs/Formatting/CantGetRidOfLine.htm
Nogle der kan hjælpe? Driver mig til vandvid!
Indlægaf Lasse B » tirs maj 08, 2007 13:04
øh... Er den bare poppet op af sig selv eller har du lavet den fx. med en masse _  ?
E.g: ______________________
Lasse B
Tilmeldt: søn maj 06, 2007 22:31
Indlægaf Raskolnikov » tirs maj 08, 2007 13:22
Ja lige netop! Den er til sidst i dokumentet og under et afsnit.  :(
Indlægaf Lasse B » tirs maj 08, 2007 13:25
Den har jeg også siddet fast ved et par gange!
Har du prøvet at copy paste selve teksten uden stregen, og så indsætte teksten i et nyt dokument?
Lige pt. kan jeg ikke huske hvordan jeg kom ud af den, men det kan gøres!
Evt. prøvet at trykke på fortryd?
Lasse B
Indlægaf Raskolnikov » tirs maj 08, 2007 13:26
Den følger med i det nye dokument... :roll:
Indlægaf Lasse B » tirs maj 08, 2007 13:29
Ja jeg efterprøvede det også lige selv...  :roll:
hmm
Lasse B
Indlægaf Lasse B » tirs maj 08, 2007 13:33
Nu fik jeg den lige til forsvinde  :D
Gjorde bare som der står i teksten du har kopieret ind...
Du markerer teksten der står over linien -> Højreklik -> Formatering -> Ingen
( Det kan variere alt efter hvad man bruger, jeg har OpenOffice, så det kan jo hedde noget andet i Word )
Men det virkede i hvert tilfælde!
Lasse B
Indlægaf Raskolnikov » tirs maj 08, 2007 13:35
Jeg bruger DESVÆRE ikke open office....hader MS ret tit!  :evil:
Indlægaf Lasse B » tirs maj 08, 2007 13:36
Nu var det heller ikke pointen - Da ovenståede tekst du har kopieret ind er skrevet til MS Word.
Altså du skal 'bare' formattere teksten til 'ingenting' eller som det hedder hos mig 'standart'
Lasse B
Tilbage til Off-Topic
