Raskolnikov skrev:Vinyl guf på CES.
En ny plov fra Pro-Ject med deres helt nye arm.
Sumiko had a new Pro-Ject turntable on display, the "approximately $2000" Perspex, which sports the new 9CC Evolution tonearm.
The table has a mag-lev suspension and tunable sub-platter assembly and plinth.
The tonearm is called "9CC" because it's a 9" model using continuous
carbon fiber. The bearing assembly seems monstrously overbuilt. "That
gives it remarkable rigidity," said Norbert Schmidt.
Ny PU fra Sumiko
Sumiko's Norbert Schmied showed us their new upscale cartridge. "What's it called?"
"Can I get back to you on that? Let's just call it the TBD," he said.
"What can you tell us?"
It has a pauferro body and a Boron cantilever. The top
plate is chrome, "for a smoother, tighter interface with the
headshell," and the backplate of the motor assembly is extremely rigid.
The generating magnets are Alnico and the stylus has a line-contact
profile. Output will be 0.5mV.
Price is projected to be substantially above that of the $2000 Celebration—possibly in the $4000 range.
De er fra Stereophile blog fra CES.
http://blog.stereophile.com/ces2008/
Sjovt nok, så ser jeg ikke det engelske/amerikanske ord "plough" nogen steder i de udenlandske tekster...
SÃ¥, det der med "plov" hvor pokker kommer det egentlig fra?????
N.
