Vinyl guf!
Indlægaf Nilau » fre okt 03, 2008 19:30
Raskolnikov skrev:Vinyl guf på CES.
En ny plov fra Pro-Ject med deres helt nye arm.
Sumiko had a new Pro-Ject turntable on display, the "approximately $2000" Perspex, which sports the new 9CC Evolution tonearm.
The table has a mag-lev suspension and tunable sub-platter assembly and plinth.
The tonearm is called "9CC" because it's a 9" model using continuous
carbon fiber. The bearing assembly seems monstrously overbuilt. "That
gives it remarkable rigidity," said Norbert Schmidt.
Ny PU fra Sumiko
Sumiko's Norbert Schmied showed us their new upscale cartridge. "What's it called?"
"Can I get back to you on that? Let's just call it the TBD," he said.
"What can you tell us?"
It has a pauferro body and a Boron cantilever. The top
plate is chrome, "for a smoother, tighter interface with the
headshell," and the backplate of the motor assembly is extremely rigid.
The generating magnets are Alnico and the stylus has a line-contact
profile. Output will be 0.5mV.
Price is projected to be substantially above that of the $2000 Celebration—possibly in the $4000 range.
De er fra Stereophile blog fra CES.
http://blog.stereophile.com/ces2008/
Sjovt nok, så ser jeg ikke det engelske/amerikanske ord "plough" nogen steder i de udenlandske tekster...
Så, det der med "plov" hvor pokker kommer det egentlig fra?????
N.
Nilau
Indlægaf Raskolnikov » fre okt 03, 2008 19:53
det er et dansk slang ord. Har hørt andre bruge det, så det er ikke noget jeg har fundet på. Puen pløjer ned i rillen på pladen.  :D
Indlægaf a2zinck » ons okt 08, 2008 20:27
dylans nye vinyludgivelse
Columbia Records is happy to announce today's release of Bob Dylan's "Tell Tale Signs: The Bootleg Series Vol. 8".
Los Angeles Times: "'Tell Tale Signs' is not just "extra" Dylan. It's essential Dylan."
San Francisco Chronicle: "For Bob Dylan, these are outtakes. Most musicians would call them their greatest hits."
The BBC: "Beautiful, brave and beguiling."
Boston Globe: "a feast for casual fans and Dylanologists alike."
prisen afskrækker dersværre en fattig studerende...
a2zinck
Geografisk sted: Aarhus
Indlægaf Raskolnikov » tors okt 16, 2008 16:14
Kan se i almeldelse af den nye Rega MC Riaa Los i Tone Magazine at den bruger transformers. Det synes jeg da er lidt interessant.
http://www.rega.co.uk/index2.htm
Indlægaf king » tors okt 16, 2008 16:35
Ja... denne Rega Riaa - skulle gøre det svært for andre gode riaa
jeg må heller snakke med min Rega forhandler om man kunne prøve dyret !!
Hør musik - ikke optagelser !
king
Geografisk sted: Aabenraa
Indlægaf Raskolnikov » ons nov 26, 2008 18:39
Har du fået lyttet på den King? For øverigt kan jeg se at der var nogle rygter om at Ios ville få rør, men dette skete så ikke. Der er yderligere rygter om at Rega arbejder på en High End for-forstærker med rør.  :D
Indlægaf Raskolnikov » søn nov 30, 2008 00:45
Zu har deres 103 til 250 dollars lige nu! Hvis jeg skulle have ny PU var der røget en bestilling afsted!
http://www.zuaudio.com/turntables.html
R modellen er også på tilbud.
http://www.zuaudio.com/turntables/dl103r.html
Indlægaf a2zinck » man dec 01, 2008 02:54
Raskolnikov skrev:Zu har deres 103 til 250 dollars lige nu! Hvis jeg skulle have ny PU var der røget en bestilling afsted!
okay, det var dælme et kort tilbud!
giv gerne lyd om lignende deals i fremtiden. :D
a2zinck
Indlægaf kibri » man dec 01, 2008 09:38
[/quote]
[/quote]
Sad med samme udbrud! - for et år siden stod den i 400$..
Indlægaf SES. » tirs dec 02, 2008 17:05
Så er han på banen igen. Jeg har købt lidt guld hos ham og det er på 1. klasse. Og kan det jo ikke være gratis. Supervinyl. Iøvrigt perfekt Ebayer.
F.eks. Ellingtons Jazz Party og Greg Brown.
http://shop.ebay.de/merchant/dancingneu ... m14&_pgn=1
ps: Man kommer nemt op i bud hvor hajerne lurer med "gode tilbud" hvis man ikke vinder en plade.
Indlægaf Janils » tirs dec 02, 2008 23:09
Ud over lidt digital "halløj" og en mindre integreret forstærker, så kommer Accuphase også med nyt til os analog tilhængere. Forventet ankomst her i løbet af det nye år.
C-27 MC/RIAA forstærker - 3 indgange og masser af justeringsmuligheder.
Forventet pris i Japan: 500.000 Yen
Komplet brochure i pdf-format:
http://www.accuphase.com/pdf/c-27_ef.pdf
Indlægaf Raskolnikov » tirs dec 02, 2008 23:19
Mums! Hvad svarer den pris til i dk kr?
Indlægaf Janils » tirs dec 02, 2008 23:34
Raskolnikov skrev:Mums! Hvad svarer den pris til i dk kr?
Lidt over 30.000,-  .. men så skal der diverse afgifter, told, moms og fragt på. Generelt er priserne i Europa noget højere end i Japan. Så et gæt vil være et sted mellem 60.000 og 70.000 kr.
Indlægaf Nilau » ons dec 03, 2008 01:46
Raskolnikov skrev:det er et dansk slang ord. Har hørt andre bruge det, så det er ikke noget jeg har fundet på. Puen pløjer ned i rillen på pladen.  :D
Kedeligt udtryk. Som du nævner det hér kan der være en vis logik i det. Men mange betegner HELE pladespilleren (værk/arm/pickup) som en "plov" og så er kæden allerede hoppet helt af!
Og som et kuriosum er en "Head Amp" efterhånden blevet til en hovedtelefonforstærker. Det er forkert.
Niels L.
Nilau
Indlægaf Raskolnikov » søn dec 14, 2008 22:06
Så er der igen tilbud på Zu. Denne gang på 103R. http://www.zuaudio.com/turntables/dl103r.html Kun idag!
Overskriften opdateret idag.
