Densens nye cdafspillere.
Indlægaf Pierre » man mar 16, 2009 09:02
Hejsa
Jeg har tidligere været ejer af en B-400+ som jeg "desværre" solgte.
Nå men jeg vil gerne have en Densen igen da jeg var vild med lyden fra 400+. Men hvilke af de nye modeller har samme rytme, guitareffekt og drive som 400+ havde.
Ved godt at jeg bare kan købe en brugt, men vil helst have nyt.
Jeg har kun lyttet til B440 af de nye, men det var på et ukendt setup, så der er ingen referance at hente der. Jeg syntes da af B400+ og XS så havde + mest guitareffekt og drive, hvor XS havde flere detaljer osv.
Så er der nogle af de nye som ligger sig op ad B400+?
(Har godt læst indlæget om Densen & Naim, men det gav ikke rigtigt nogle svar tilmig om de forskellige modeller.)
Pierre
Pierre
Re: Densens nye cdafspillere.
Indlægaf meitnerfan » man mar 16, 2009 12:47
Pierre skrev:
Hejsa
Pierre
Mange kan vist bedst lide de gamle.
På hifi4all linker nogen til en test i australien, som har testet 410
It seems this player lacks insight. The harder one listens, the more evident it becomes there is some veiling of details and it is hard to focus completely on the music.
Exactly how this comes across depends on the music. With large ensembles – symphony orchestra, multi-layered rock and so on – it's a question of how easily one can hear the inner parts, follow what they are playing and locate them within the stereo image. With simpler music such as voice and guitar, there's a slight but irritatingly persistent ‘fog', which seems to affect the musical message more than any specific hi-fi attribute one can point to. Good piano recordings seem to lose some of the instrument's individual character, while subtle low bass lacks tunefulness and precision.
Intrigued as to what was causing this, we ran some lab tests on the player, which showed that its performance in almost every area lags current standards for decent players at a quarter the price. Jitter and distortion in particular are considerably worse than figures we've obtained for recent budget players, while noise is no better than mediocre and stop-band rejection average. We're also concerned about clock accuracy, which is very poor at 650ppm error – more than far enough from spec to prevent many DACs from locking to the B-410's digital output. Finally, mechanical noise from the transport is higher than we'd like, with both a continuous hiss and a periodic clicking noise.
Der er vist noget med at de første spiller lidt for højt, men det er vist ikke det som de har problemer med i australien.
Måske Densen snart kommer med en SACD afspiller med godt løbeværk i.
meitnerfan
Tilmeldt: lør mar 14, 2009 13:50
Indlægaf Thomas Sillesen » man mar 16, 2009 12:53
Hej meitnerfan,
Den australske test, er så vidt jeg er blevet oplyst en afart af den dårlige engelske vi fik, grundet fejlen med niveau. De måler da også ens. (og anderledes end dem vi producerer efter fejlene var rettet).
Efter vi fik rettet fejlene, har vi vist kun fået gode test, altså efter medio 2007. Således blev B-410 årets CD afspiller i blandt andet Hong Kong og Kina, (vores B-440 er lige blevet det i 2008). Den eneste engelsksprogede test jeg kan finde efter midt 2007, er denne:
http://hifi-freaks.dk/webshop/reviews/HiFi_World_july_2007_vol1_no_05.pdf
Men uanset gode eller dårlige tests, er det væsentlige jo hvad man selv synes, så det er vel bare at lytte lidt selv.
Thomas Sillesen
Thomas Sillesen
Geografisk sted: Esbjerg
Indlægaf Pierre » man mar 16, 2009 15:47
Thomas det må du da kunne svare på.......
Hvilke af de nye afspillere svinger mest ala B400+
Pierre
Indlægaf Thomas Sillesen » man mar 16, 2009 17:15
Hej Pierre,
Det synes jeg faktisk de alle gør  :wink: B-410 er i virkeligheden en B-400+ med en anden strømforsyning og løbeværk: væsentligt større trafo men ikke dual mono, og 30.000uF istedet for 50.000uF, og et værk der har en bedre clockstyring end det i B-400+. Så det er lidt frem og tilbage med hensyn til fordele og ulemper.
De større synes jeg (selvfølgelig) er bedre  :wink:
Thomas Sillesen
Thomas Sillesen
Indlægaf LarsPalle » fre jun 12, 2009 12:54
Er der andre der har hørt de nye Densen og kan fortælle lidt om lyden ?
LarsPalle
Tilmeldt: lør nov 12, 2005 12:58
Densen B-420/B-440
Indlægaf getprogs » tors nov 12, 2009 13:33
Hej!
Startede med en B-420 som blev opgraderet til en B-440.
Det er ikke lyden den er gal med på de to maskiner - i hvert fald ikke den der kommer ud bag på apparaterne... Generelt synes jeg B-440 har lidt bedre bas og er knap så lys, men det kan være min hukommelse der snyder da jeg af naturlige årsager ikke har haft de to ved siden af hinanden ;-)
Det problem maskinerne har er den anvendte CD transport - som du også kan se andetsteds på dette forum er der flere brugere der ikke synes det er overbevisende, og det må jeg helt tilslutte mig. Største problem er de mekaniske lyde der kommer fra CD skuffen selv under afspilning - de er høje nok til at være ret generende i et normalt setup; jeg vil gætte på at du er nødt til at pakke din CD ind i et passende skuffedarium med lidt isolering for at forhindre tikke/brummelyde i at trænge ud og forstyrre.
Alt i alt har jeg fortrudt, men det kan være du kan leve med det?
getprogs
Tilmeldt: tors nov 12, 2009 13:02
Indlægaf E45 » tors nov 12, 2009 15:41
Jeg er bestemt ikke elektronik kyndig, så jeg må spørge mig vej frem: Den jitter de måler som værende alt for høj (som jeg har hørt er et unode og som skal være så lav som mulig) har dens niveau noget at gøre med de (for) høje udgangsspændinger som nogle af de første B-410 havde?
Har den anden ting de måler der er for høj (det er noget de kalder clock ustabilitet) også sammenhæng med den for høje udgangsspænding som B410 havde?
Så det der er det gennemgående spørgsmål er at efter den høje udgangsspænding er rettet af Densen, er de andre slemt høje værdier så også faldet, eller er der ingen sammenhæng?
Her bringer jeg lige det citat jeg tænker på:
E45
Indlægaf TheDuke » tors nov 12, 2009 17:51
Hvis det er rigtigt du er hifi huset E45, så er det da godt du har lukket butikken, for hifi fatter du vist ikke, hvis du tror mekaniske lyde har noget med jitter at gøre  :lol:  8)
TheDuke
Indlægaf E45 » tors nov 12, 2009 18:02
@, lige en tone ned, tak. Gider du lige læse citatet jeg henviser til??
Der står da sort på hvidt at CITAT:
"Jitter and distortion in particular are considerably worse than figures we've obtained for recent budget players, while noise is no better than mediocre and stop-band rejection average."
"We're also concerned about clock accuracy, which is very poor at 650ppm error – more than far enough from spec to prevent many DACs from locking to the B-410's digital output"
I disse to er der ikke et ord om mekanisk støj. Det kommer senere i artiklen, så rolig nu, du!
E45
Indlægaf TheDuke » tors nov 12, 2009 18:21
Hvad har det så med mekanisk støj fra et værk at gøre ?  :lol:  :shock:  :lol:
TheDuke
Indlægaf dksoulman » søn nov 15, 2009 10:22
"og anderledes end dem vi producere efter fejlen blev rettet" ????
Vil det så sige af dem der købte en 410 før medium 2007 bare har en cd afspiller som er fejl produceret???
Det synes jeg ikke er smart.
Rod Stewart "Every Picture Tells A Story"  1971
dksoulman
Tilmeldt: ons feb 22, 2006 21:27
Geografisk sted: Odense
Well...
Indlægaf getprogs » søn nov 15, 2009 12:14
Densen har jo livstidsgaranti (til den første ejer), så hvis man synes der er et lydmæssigt problem tager man da bare kontakt til [email protected]?!
Så kan man samtidig købe en opgradering til 420/440 - som en lille "før"-julegave ;-)
getprogs
Indlægaf dksoulman » søn nov 15, 2009 13:18
Måske, nu er det ikke mig som har den. Men et famile medlem.
Det er vil også et spørgsmål om Densen ankender det som en fejl. Og måske ikke bare en opdatering, altså forbedring de har lavet.
dksoulman
Indlægaf ulrikmm » søn nov 15, 2009 21:13
Pas på med hånligheder i offentlighed - de siger mest om afsenderen.
ulrikmm
