Belting Tweak!
Belting Tweak!
Indlægaf ZIG » fre apr 10, 2009 15:04
Det er påske og vi har lidt tid. Her er nogle forslag til et par tweaks.
http://www.belt.demon.co.uk/Free_Techniques/Free_Techniques.html
Og jeg ved godt, at jeres første reaktion vil enten være at grine eller græde.....MEN.... om ikke andet, så synes jeg, der er det overordnede princip, at man kan gøre noget (ekstraordinært) for at fornye sin lytteoplevelse.
Lidt teori fra Michigan J Frog - Stereophile Forum.
"Belting": The use of products and or ideas based on the (revolutionary) discoveries of Peter Belt, (a UK audio engineer), about a quarter of a century ago. They are not your typical "audio tweaks" and not the typical ideas, applied to sound reproduction, as they have no effect on the audio signal, room acoustics, or any of the traditional ways of improving sound. The applications affect (and improve) only the listening process itself. In short, the discovery Belt happened upon is that the human listening process is affected by energy patterns in our local environment, that reduce our hearing abilities (which is thought to be due to stresses we have inherited from since the beginning of our species). The applications (whether home-made or commercially purchased) attempt to change the energy patterns in our environment to ones more benign to our senses, and where successful, this improves the sounds we hear in ways no other audio applications are able to do. Rather than just change the frequency spectrum, or even phase, as many audio products do, improving sound by way of "Belting" basically just makes things sound more natural. It creates a less aggressive sound, greater realism within the sound, and stronger emotional bonds with the music you hear (whether it's live or reproduced). (This can even be -very- strong sometimes, just after an application).
Nu vil jeg prøve at bytte sko.... og sætte en plade på, som jeg ikke kan lide....måske virker det.
Indlægaf Janils » fre apr 10, 2009 15:20
Ja, tag et billede af dig selv. Læg det i fryseren og du hører bedre. Prøv så at sætte et rødt "X" på bagsiden af billedet, inden du lægger det i fryseren. Med samme pen (vigtigt) laver du et tilsvarende "X" på undersiden af dine apparater. Nu ikke alene hører du bedre dit anlæg bliver også meget bedre!
Dette blot et enkelt af Belts obskure tweaks. Og jeg glemte faktisk det bedste af det hele - efter denne lille øvelse smager såvel dine bøffer og rødvin som din whisky bedre! Men altså kun så længe billedet ligger i fryseren!
Jeg foretrækker nu at springe det hele over og nøjes bare med whisky'en  :D
Indlægaf Kim Olsen » fre apr 10, 2009 15:36
jeg videreudviklede ideen for en del år siden, patent pending, ved at tilføje en nøjsomt udvalgt proces før whisky'en indtages. meget forenklet går det ud på at man inden da har indtaget adskillige kolde øl, helst i godt selskab. der blev skrevet et whitepaper om det for nogle år siden, men de bortkom da Lars Løkke var med i en blindtest der gik lidt over gevind. min revisor brokker sig stadig over de bilag der gik tabt i den forbindelse
Indlægaf ZIG » tirs apr 21, 2009 10:14
Jeg vender tilbage til dette emne, fordi jeg ikke synes det er udtømt!
Jeg giver dig ret Janils, at der er noget dybt åndsvagt over de "tweaks" du påpeger. De er uæstetiske og man er i bund og grund enfoldig, hvis man falder for dem!
Jeg synes til gengæld, at Kim er på rette spor.
Anlægget lyder ikke éns fra aften til aften og man er ikke altid garanteret en optimal lytte-oplevelse. Tit har jeg slukket for anlægget - fordi jeg ikke kan finde den rigtige plade, eller jeg finder den rigtige plade, men jeg kan ikke finde det rigtige humør.
Oplevelsen er afhængig af mangt og meget. Alkohol er til tider en udmærket equaliser - men måske ikke lige kl. 10.00 om morgenen (vel Kim?). Hvis jeg har ufærdige opgaver, der venter på mig, kan jeg ikke bare nyde at sætte at sætte en plade på.
At bladre igennem diverse anmeldelser kan også tweake éns hørelse - anmelderens entusiasme kan især smitte. En musikaften med venner kan man leve længe på. At købe noget nyt er også en tweak - man lytter igen med fornyet opmærksomhed - uanset om det er software eller hardware.
Det er noget af en kliché, når man læser, at vores hobby handler først og fremmest om musik. Den handler også om isenkram og når kedsomhed melder sig, er man nødt til at tweake sin opmærksomhed. En løsning er at købe noget nyt!
At komme med indlæg her på Nerds er også en slags tweak, for så er man med i en bevægelse (for nu at bruge et 60'er ord), hvor man deler nogle fælles forudsætninger og begejstring.
Så jeg vil egentlig sige, at hvis man har valgt hifi som hobby, så er man igang med at tweake hele tiden - for bare at holde sin interesse vedlige.
Begejstringen og det specielle ligger mellem ørerne.
