http://www.belt.demon.co.uk/Free_Techniques/Free_Techniques.html
Og jeg ved godt, at jeres første reaktion vil enten være at grine eller græde.....MEN.... om ikke andet, så synes jeg, der er det overordnede princip, at man kan gøre noget (ekstraordinært) for at fornye sin lytteoplevelse.
Lidt teori fra Michigan J Frog - Stereophile Forum.
"Belting": The use of products and or ideas based on the (revolutionary) discoveries of Peter Belt, (a UK audio engineer), about a quarter of a century ago. They are not your typical "audio tweaks" and not the typical ideas, applied to sound reproduction, as they have no effect on the audio signal, room acoustics, or any of the traditional ways of improving sound. The applications affect (and improve) only the listening process itself. In short, the discovery Belt happened upon is that the human listening process is affected by energy patterns in our local environment, that reduce our hearing abilities (which is thought to be due to stresses we have inherited from since the beginning of our species). The applications (whether home-made or commercially purchased) attempt to change the energy patterns in our environment to ones more benign to our senses, and where successful, this improves the sounds we hear in ways no other audio applications are able to do. Rather than just change the frequency spectrum, or even phase, as many audio products do, improving sound by way of "Belting" basically just makes things sound more natural. It creates a less aggressive sound, greater realism within the sound, and stronger emotional bonds with the music you hear (whether it's live or reproduced). (This can even be -very- strong sometimes, just after an application).
Nu vil jeg prøve at bytte sko.... og sætte en plade på, som jeg ikke kan lide....måske virker det.
