Logically manufacturing turntables that already create that feeling, turntables with exceptionally low background noise and impressive isolation to prevent distortion, we wanted to create a phono stage that embodied these qualities.
For that reason our design is fully balanced throughout, keeping noise exceptionally low. Distortion across the audio spectrum is very low and with an impressive headroom, there's never a feeling of 'running out of steam'. A purpose designed separate, double regulated power supply with a large 300va transformer provides dedicated power to each channel.
Inputs and outputs are both XLR and RCA, and whilst running fully balanced internally, the output is optionally balanced or unbalanced.
Gain, resistance and capacitance are all easily adjustable from the front panel and offer exceptional flexibility.
Entirely manufactured within our own facilities, everything from PCB assembly, testing and quality control to the high quality casework is designed to complement our other products and blend well with others, making our first phono stage a long lasting reliable product, allowing you to not just listen, but experience the full potential that vinyl replay has to offer.
Specifications
Noise | : < 75dB |
Distortion | : < 0.003% |
RIAA | : 20Hz - 20kHz +/-0.5dB |
Gain | : 40dB - 50dB - 60dB - 70dB |
Resistance loading | : 10R - 30R - 100R - 500R - 1k - 5k - 10k - 47k |
Capacitance loading | : 100pf - 200pf - 500pf - 1.5nf - 10nf - 20nf |
Power supply | : Double regulated with 300va transformer |
Voltage input | : 100-240vac 50/60Hz 10 watts max. (depending on region) |
Dimensions | : 290 x 240 x 100mm (WxDxH) |
Net weight | : Control unit - 3.8Kg (8.4lb) PSU - 6.4Kg (14lb) |
Packaging | : 370 x 310 x 300mm (WxDxH) |
Shipping weight | : 11.0Kg (24lb) |
UK SRP | : To Be Confirmed |
