AVID - Pulsare Phono Stage
Indlægaf king » fre aug 28, 2009 05:56
Så kommer der en fed riaa fra Avid
Selvom jeg har solgt min pladespiller, ville jeg sku gerne høre denne riaa !
This was our design goal, because over the years, the many phono stages we have listened too, whilst offering excellent technical performance, lacked that something that makes the music sound and feel real. We call it 'shear power'. Its that feeling of presence, solidity and drive that separates just listening to a hifi system with the feeling of being in the presence of the performance.
Logically manufacturing turntables that already create that feeling, turntables with exceptionally low background noise and impressive isolation to prevent distortion, we wanted to create a phono stage that embodied these qualities.
For that reason our design is fully balanced throughout, keeping noise exceptionally low. Distortion across the audio spectrum is very low and with an impressive headroom, there's never a feeling of 'running out of steam'. A purpose designed separate, double regulated power supply with a large 300va transformer provides dedicated power to each channel.
Inputs and outputs are both XLR and RCA, and whilst running fully balanced internally, the output is optionally balanced or unbalanced.
Gain, resistance and capacitance are all easily adjustable from the front panel and offer exceptional flexibility.
Entirely manufactured within our own facilities, everything from PCB assembly, testing and quality control to the high quality casework is designed to complement our other products and blend well with others, making our first phono stage a long lasting reliable product, allowing you to not just listen, but experience the full potential that vinyl replay has to offer.
Specifications
Noise
: < 75dB
Distortion
: < 0.003%
RIAA
: 20Hz - 20kHz +/-0.5dB
Gain
: 40dB - 50dB - 60dB - 70dB
Resistance loading
: 10R - 30R - 100R - 500R - 1k - 5k - 10k - 47k
Capacitance loading
: 100pf - 200pf - 500pf - 1.5nf - 10nf - 20nf
Power supply
: Double regulated with 300va transformer
Voltage input
: 100-240vac 50/60Hz 10 watts max. (depending on region)
Dimensions
: 290 x 240 x 100mm (WxDxH)
Net weight
: Control unit   - 3.8Kg (8.4lb)    PSU   - 6.4Kg (14lb)
Packaging
: 370 x 310 x 300mm (WxDxH)
Shipping weight
: 11.0Kg (24lb)
UK SRP
: To Be Confirmed
Her er et link
Hør musik - ikke optagelser !
king
Geografisk sted: Aabenraa
Indlægaf WRONG » fre aug 28, 2009 17:35
Ser meget seriøs og lækker ud. Nogen der ved hvad den komme til at koste?
MVH WRONG 8)
VINYL ER HYL!
WRONG
Tilmeldt: tirs nov 22, 2005 16:46
Indlægaf king » man aug 31, 2009 05:46
WRONG skrev:Ser meget seriøs og lækker ud. Nogen der ved hvad den komme til at koste?
MVH WRONG 8)
Ja... Morten den er fed tror bare, at den måske kommer til at koste 1million.....
king
