- Video: fix some audio glitches after seeking WMA files
- Video: add support for MTS files
- Video: bring UTF-8 and UTF-16 encoded subtitles format support
- Video: fix SUB subtitles sometimes truncated
- Video: add IDX/SUB subtitle handling
- Video: fix http://.*mpeg playback
- Video: support resume and bookmark for network shares
- Video: fix some FLV files not playing
- Youtube: fix mobile site video not playing
- Multimedia: fix RTSP support for Android applications
- Multimedia: fix some web radio applications by adding basic M3U support
- Audio: apply shorter steps in audio balance tuning
- Audio: fix sound glitch on system notification while playing music
- Music browser: fix album view crash on scroll with a lot of albums
- Music: support samba protected directory access
- Thumbnails: resolve thumbs generation freeze
- Indexing: improve rescan robustness
- Indexing: fix scanning not restarting after connecting device on PC or ejecting SDCard
- Network shares: large files (>2GB) can now be played
- Wi-Fi: fix disabling power saving not working
- Wi-Fi: enable IEEE802.11n support
- Wi-Fi: achieve faster reconnection
- SDCard: fix sdcard removal not being taken into account
- Storage: enable EXT3 filesystem support and migration
- USB keyboard: fix external directional keys layout when rotating the device
- Memory: enable 32MB swap by default and increase it to 64MB after Android reset or full device reformat
- Applications: fix applications disappearing sometimes between reboots
- Applications: fix unit not responsive after Google voicesearch use
- Power management: allow to define deep sleep mode by default in settings/about device/power management
- VPN: PPTP VPN support has been fixed
Med Archos tablets er Android for første gang blevet hurtigere end du kan tænke,
For pokker, hvor er Android OS blevet hurtig efter firmware opdateringen der primært har haft til formål at optimere hastigheden til alleryderste. Den er nu ekstremt hurtig til at tænke og den er fuldstændig flydende i brugerfladen. En benchmark score på omkring de 1500 fortæller da vist også alt.!
Archos levere alt det, mange andre producenter stadig ikke har fået styr på. Android OS er blevet driftsikker uden force close i tide og utide. Bugs eller det der ligner er der ikke mange af - jeg har ikke fundet dem endnu. Derfor mine varmeste anbefalinger til Archos tablets. Det er de bedste 1900 kroner jeg nogensinde har givet ud for et stykke elektronik.
Archos Gen 8 er blevet en stor familie
Firmware update (2.0.54) running on Android 2.2.1 (FROYO)
Download firmware via din PC, tilslut din Archos tablet , træk ny firmware over i hovedmappen kaldet Archos, genstart din tablet, klar til brug - denne gang langt bedre og hurtigere end man kan forestille sig!
http://www.archos.com/support/support_tech/updates.html?country=dk&lang=enfirm
Wi-Fi: fix Wi-Fi stuck after a while when using WPA2/AES encryption mode
Wi-Fi: fix cannot connect on channels above 11 due to wrong default regulation domain
Power
management: for A43/A70/A101 add a setting in about device to allow 3
levels of power management. Overdrive that allows CPU max frequency to
be 1GHz with ondemand governor, optimal that brings CPU max frequency to
800MHz with ondemand governor and powersave that set CPU max frequency
to 800MHz with conservative governor
Indexing: faster rescan is now achieved at USB disconnect
Storage: SDCard now supports NTFS (read only) and EXT3
Storage: fix sdcard not recognized sometimes when swapping different cards brands
Video: fix subtitles on A101
Network shares: enhance scanning speed
Network shares: handle the case where a server shares are not visible if not authenticated
Network shares: allow in wireless settings to define manually a server authentication details
Network shares: reload samba and UPnP services when switching between access points without disconnecting
Audio:
a silent mode (Global Mute) has been enabled in the power button menu.
It will impact all streams except alarms in case one select alarms sound
always on in alarm settings
Application: appslib is now reinstalled after an Android device reset
Application: fix quadrant CPU benchmark
Power: fix shutdown sometimes happening on short power button press
Internationalization: support for Korean codepage tags and subtitles
Multimedia: use smaller memory footprint for decoding H264 SD
Memory management: achieve more progressive kill in low memory situation
Boot: fix deadlock happening sometimes preventing device to complete boot
